front wheel center line info
I'm hoping someone can help me out with some info. I am looking for a point to measure from and the measurement on the frame of a '63 (60-66) to find the wheel centerline of the front wheels when aired out so they are centered in the wheel opening. I know it needs to move forward some but am just not sure how much. Thanks.
Check out my build thread for my '63: http://67-72chevytrucks.com/vboard/s...49#post4806049 |
#2 | |
Re: front wheel center line info
needs more $$$
^Scoti answered it, but just incase you want to check it out on your rig....take the center of your wheel well opening and drop a plumb string (make sure the frame is as level as possible). Then use that as your reference for the spindle.
1970 2wd Blazer |
UCA63
If the 60-66's has a flaw,this would certainly be it(at stock hieght or lowered).
When I did my XM swap I kept it basic,(because its my 1st one) 2 holes to drill vs 14 PS box/bumper bracket rework The location of the rad support XM also may come into play with this mod Now that I'm done I kinda wish that I did move it forward(to facilitate future mods like lowering),it's still a rolling chassis so its not too late yet T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
