07-24-2011, 07:17 PM | #1 |
73-87 HD brake question
I have a 68 C10 with the 73-87 front K member swap. I have 1.25 HD spindles, McGauhys Part # 6072L/R. I need to finish up the brake system on my truck.
Any recommendations for rotors and calipers? I'd like to upgrade a bit, maybe run some bigger rotors and calipers if possible. Are there any hybrid swaps out there? Corvette, etc. ? Thanks.
07-25-2011, 07:49 AM | #2 |
Re: 73-87 HD brake question
mcmixix has just done a complete dana 60 front complete upgrade in the 4x4 section of this forumn. He is alost done the upgrade. Using newer bigger Dodge parts. I think you posted this question in the wrong place. I am sure a senior member with move it. You posted in the forsale section.
07-25-2011, 09:48 AM | #3 |
6.0 powered square
I have seen c-4 vette brakes setups but they used a porter built c-4 drop member, How big of brakes you need wilwood makes 14" rotors with 6 piston calipers, they also make d-52 dual piston calipers which are a direct bolt in for stock calipers which will allow you do use 15" wheels which I may run on my truck on the front and rear
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
