04-06-2003, 01:21 AM | #1 |
Turbo 400 Kickdown
The Transmission kickdown switch was found dangeling between the engine and firewall of my truck when the Engine and transmission were pulled the other day, I have not had this truck that long, and appears to have been hanging for quite some time, I'm not sure where is is suspost to be mounted, Can someone please help? The truck has a 350 connected to a Turbo 400, if anyone has any pictures it would be greatly appericiated. Thank You,
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
04-06-2003, 10:49 AM | #2 |
Here you go!
04-06-2003, 09:44 PM | #3 |
Thank You
Thank you Jim, I will be attempting to connect it within the next few days.
04-15-2003, 10:32 PM | #4 |
Switch Seems to work
I haven't mounted the kickdown switch yet, however when it is depressed you can hear the relay in the trans clicking, should be connectinging it next week, however also having trouble with the secondaries not kicking in on the carb, The accelatator linkage will need to be adjusted and I think everything will work properly. eventually I want to replace the Holley 600 with and Edelbrock performed anyways.
