Old 07-26-2011, 10:00 AM   #1
BurnoutNova
BurnoutNova's Avatar
5.3 or 6.0 LSx swap in 72 K10?
I am doing some research on this. I was thinking this would be a relatively easy swap, IF you want to keep the th350 trans. Ideally I'd like a 4L60e, or a 4L80e. The trouble is the t case output on all the newer stuff is on the drivers side, and the original 205 is on the passenger side. So that means swapping a Ford or some other diff that has the driver side pinion, correct?
It would need to stay solid axle, a IFS is not something I want to do on this truck.
I'm sure someone has already done this swap?
BurnoutNova is offline   Reply With Quote
Old 07-26-2011, 01:30 PM   #2
ncgamedog
Re: 5.3 or 6.0 LSx swap in 72 K10?
http://67-72chevytrucks.com/vboard/f...play.php?f=206
You could still run a GM 205. Just because the trans originally had drivers drop T-case, doesnt mean you cant run a passenger drop case. Its not like the trans spins a different way or anything.
The 4l60e is basically a newer version of the th305/700r4. While there are marked differences, the output shaft on the 4l60e is still 27 spline like its earlier predecessors. This means that you can mate a th350 version 205 behind it, as those had 27 spline inputs. It will require that you use the earlier (1992-97) 4 bolt flange version of the 4l60e, combined with a 2" aluminum spacer and normal th350 T-case adapter. The 4l60e has a longer output shaft than the th350/700r4. There is a short shaft available to convert the output shaft of the 4l60e to the same length as the th350/700r4, but some cite tranny pan interference with the front driveshaft.
The same logic follows with the 4l80e, as it is still 32 spline like the th400. You could use a th400 version 205. These cases are harder to come by and more expensive. But of coarse, a much better setup.
either would be fine for most applications.
ncgamedog is offline   Reply With Quote
