Old 07-26-2011, 05:48 PM   #1
RRR18
RRR18's Avatar
Transfer Case Encoder Motor
What a pain this thing is! Changing the part no problem at all. Finding out that it is the problem ! My bad Transfer Case Encoder Motor on my '03 Z71 (92K) caused unbelievable problems.
1. Made the lights on push button case switch go crazy. Blink or just plain went out.
2. Stalling.
3. A/C cycled in and out over and over.
4. No power at all. Foot to floor....25 miles an hour.
5. Shift patterns way outta wack. Wouldn't downshift either.
6. Obviously had no 4WD and SERVICE 4WD code popped up.
After all that and a very smart mechanic that I know and about 4 hours making sure there wasn't anything else wrong with any part of the truck the Encoder Motor was found to be the only culprit. Truck threw out 4 codes with one being the CO 327 Encoder Circuit Malfunction. Most of time spent was to make sure the truck didn't have multiple problems so that we were't just throwing parts at it. Changed the part and EVERYTHING back to normal!
Thank god for really smart computer mechanics. Just thought I'd share...maybe it'll help someone sometime.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 07-30-2011, 01:17 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Transfer Case Encoder Motor
Interesting, glad ya got her fixed.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-29-2011, 06:11 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
this should be a sticky!
chased down a bunch of info, and it seems that this is a very common problem...!
been doing lots of google searches to see how to replace this part, 2005 silverado..
is there anything special I should do, or is it just a simple remove and replace?
Old 08-29-2011, 11:33 PM   #4
RRR18
RRR18's Avatar
Not simple as remove/replace. After part is changed it has to be programmed to the trucks computer.
'67 BAD IDEA
Ryan
Old 09-08-2011, 11:23 PM   #5
shade67
They used to sell the encoder itself- you removed the shift motor and split it's case and replaced it- now you buy the rebuilt shift motor and replace it - I've never had to reprogram anything just make sure t-case is in neutral before reinstalling shift motor and the shift motor slides uptight to t-case before tightening or it'll break, hook up the connector and turn on the key- should show light by the "n" push 2wd and shift trans to neutral and it will shift!
Scott
66 chevy short step 327 4speed
67 chevy Short Fleet tpi 350 700r4
72 chevy K10 swb
01 GMC Sierra
01 Pontiac Bonneville
shade67 is offline   Reply With Quote
