Old 07-26-2011, 11:07 PM   #1
Macs66-C10
Macs66-C10's Avatar
What carb do you recommend to replace Rochester
I have a completely stock '66 with a 283 and powerglide. Starts pretty easy but definitely needs a rebuild...or better yet, a whole new setup.
Should I use another, more modern 2 barrel or change the intake and go with a 4 barrel? I would assume that a 500 cfm would be plenty big enough...
What do you guys like?
Macs66-C10 is offline   Reply With Quote
Old 07-26-2011, 11:38 PM   #2
Blue Heeler
Blue Heeler's Avatar
Re: What carb do you recommend to replace Rochester
I would slap a Quad on there, they are pretty reliable and easy to work on.
Blue Heeler is offline   Reply With Quote
Old 07-27-2011, 12:09 AM   #3
awbrown
with a quadrajet you can adjust the secondaries if the engine doesnt want all that air .........and it will get better mpg than anything else you will find .... my second choice would be a 500 afb.........
awbrown is offline   Reply With Quote
Old 07-27-2011, 09:00 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
500cfm Edelbrock. I have that on my 305 and it works perfect.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-27-2011, 11:06 AM   #5
jimmydean
jimmydean's Avatar
This. Carter/Edelbrock (both made by Weber still, I think) AFB, set and forget goodness.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-27-2011, 11:31 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
For a stock 283 with a Powerglide in a heavy truck, I think that a Rochester 2bbl is just fine. If you decide to step to a 4bbl, keep it small, no bigger than 600cfm and definately vacuum secondary.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-27-2011, 09:14 PM   #7
awbrown
There's always a bunch of carbs on ebay , just seems more and more people are driving new stuff and carbs get cheaper everyday...
