1 piece driveshaft on a longbed
Anyone running a 1 piece driveshaft on a 2WD longbed? I got the complete rear suspension kit from Air Ride Technologies which includes a new crossmember that doesn't accept the mounting of a carrier baring. Called Denny's driveshaft, and they won't build one that long for safety reasons.
Re: 1 piece driveshaft on a longbed
my 67 lwb 2wd has a 1 piece driveshaft. its a 250 i6.
Its a Truck Thing......
I think your going to run into that problem everywhere you go. I had people that was nervous about making one for my shortbed.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
I am running one, no issues here... was on the truck when i bought it.... I have the paper work for it so I might be able to tell you some things about it
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
I am running one also..my 4/6 drop was doing this to my carrier bearing[Below}
talked to my driveshaft guy and was within the maximum overall length he requires..without going to a giant diameter aluminum unit..my truck has a T-400 tranny{I installed} so the overall length might be different than a stock ride. Smooth as silk! ![]() |
the 73-87 long beds (or at least the one i had) came with a one piece drive shaft from the factory, so i don't know why one couldn't be made for one of these
Fabricate till you "puke"
A longer tailshaft on the trans,as well as engine placement, let the 73-87 trucks run a shorter lenght 1 pc shaft. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#9 | |||
"I ain't nobody, dork."
Gary
the boat guy
we build them. Pretty sure we make them out of 3" tubing. As long as you're not running an od trans w 411 gears the lenth shouldn't be a problem.
Brad Man 72
I have a Turbo 400 in a shortbed '69, and I am having a one piece driveshaft built. My measurement comes out to 59" from the splined trans shaft to the center of the U-Bolt cup . Do you think that will work OK? NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
the boat guy
no problem noneck. some 67-72 swb had one piece shaft from the factory.
If I remember from having one made for my '69, you need 71" u joint to u joint. OOPS..I had a 700r4 in it, still it was no problem to build.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
brad_man_72, I'd like to get one ordered. Do you have some ordering information for ordering a custom driveshaft?
#15 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I had a driveline shop build mine. I never had any issues with problems. The truck comes with a built in driveshaft loop anyway.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
