Old 07-29-2011, 10:31 AM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Tow Bar question
I've had no experience in these, how safe and would it be a bad idea to have a guy pull a 4x4 72 blazer for me from NW USA to Ks? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 07-29-2011, 11:07 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Tow Bar question
Randy, that is all i used to use back in the day. The question is, what is he pulling it with? A blazer is pretty heavy. That is along way to go with a tow bar... i would probably look at a dolly or trailer for that distance.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-29-2011, 11:17 AM   #3
Dunenutt
Newbee
Dunenutt's Avatar
What he said^^^! That blazer is going to wig wag in the ruts, unless it's behind a bus or something.
Dunenutt is offline   Reply With Quote
Old 07-29-2011, 07:39 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
as long as the truck is up to the task, then there should be absolutly no problem at all, and no wig wagging either.
I've used tow bars WAY more than I've used trailers, never had an issue when i was doing it properly, and only had minor issues when I wasn't doing it right.
Old 07-29-2011, 07:53 PM   #5
stich626
remember to drop the driveshaft if you can't get the transfer case in n
stich626 is offline   Reply With Quote
Old 07-30-2011, 04:39 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
I pulled a '67 K/10 Suburban -- with a burned out BBC and a full load of gear in the back -- behind a U-Haul F-350 from El Centro Cal to Tucson AZ with no problems. U-Haul didn't have a tow dolly big enough, or a flatbed trailer available, so they sold me a tow bar for $100. I got home OK.
A few years later, sight unseen, I bought a '72 K/5 rolling body [ frame, axles, tub and tires, no body parts] in Lake Havasu. Pulling it on a U-Haul flatbed behind my '71 Jimmy 4x4 back to Tucson was a real dog. And a lot more expensive.
Old 07-30-2011, 09:00 AM   #7
teeitup
teeitup's Avatar
Thanks for the info guys, I think he is going to get a trailer now. Randy
1980 chevy swb 4x4
Old 07-30-2011, 09:07 AM   #8
eurospec1
eurospec1's Avatar
Gotta pull the driveshafts, no matter if transfer goes in nuetral or not.
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 07-30-2011, 09:26 AM   #9
stich626
how do the motorhomes do it, they don't pull the shafts every time they tow the car/truck behind it
Old 07-30-2011, 10:54 AM   #10
eurospec1
eurospec1's Avatar
most motorhome owners have quick disconnects on their driveshafts. The problem with leaving the driveshafts hooked up is they still spin the output shafts of the trans or transfer case, without the iput shaft spinning their is no lubrication to those output shaft bearings and you can easily burn them up. Does it always happen, no, but much better safe then sorry.
68 SWB Fleet 383
Old 07-30-2011, 11:41 AM   #11
stich626
I've always pulled them but figured it was different with 4by4
Old 07-30-2011, 12:34 PM   #12
pumpkin
pumpkin's Avatar
I've put 12000 miles on my Blazer towing behind a 24 ft airstreem motorhome. I did build the towbar myself and made sure it was heavy duty. I also built a surge brake into the towbar. Transmision in park T case in nuetral and no problems. Towed like a dream, and its the fastes the blazer has ever been. Had up to 95 miles an hour on the I 5 around LA. Because of the weight of these trucks, if you don't have it balanced well on a trailer it will tow like ass.
pumpkin is offline   Reply With Quote
Old 07-30-2011, 09:28 AM   #13
Hart_Rod
Hart_Rod's Avatar
I pulled a 68 SWB BB loaded down with parts from Alubuquerque, NM to Pensacola, FL (1400 mi) with zero problems. I was using a 07 Chevy HD with a Duramax, so that might have helped a little......
Hart_Rod is offline   Reply With Quote
