Slow Idle- 04 Sierra
When I come to a stop sign, it will idle at 400-500 rpm for the past 2-3 weeks. I have cleaned the air filter (k&n) and Mass air sensor. I am pretty sure I do not have a IAC valve or even a MAP sensor. Related or not, I can not spin the tires no matter how hard I try. Low idle doesn't seem to affect its driveabilty other than the slow idle. No codes either.
Has anyone experienced this? Any suggestions what to look for?? Thanks
1987 Chevy R10 2004 GMC Sierra 1980 Chevy Malibu |
Re: Slow Idle- 04 Sierra
I have a 01 silverado that would idle slow and sometimes quit when I started it. It has a 6.0L, I replaced the IAC and that did not help then I replaced the fuel filter and the fuel pressure regulator and that fixed it. the Fuel filter had actually fallen appart internally and was blocking the outlet. You can test the fuel pressure at the test port on the fuel rail. I used an old set of refrigerant gages and verified the pressure after I changed the regulator and filter.
Hope that helps Navysnipe |
Thanks Navy
I hope it is not the fuel filter (it is all one piece with the fuel pump! ![]()
Clean the throttle body bore.
I did a while ago, but I will definitely do it again.
Fuel filter is under the drivers side on the inside of the frame... Mine is anyway. My throttle body was getting dirty and the only thing that it was causing was a sticky throttle(closed). I just adjusted the stop screw a little bit more open and the IAC compensated for that and the idle settled down where it was supposed to.
Navysnipe |
#7 | ||
"I ain't nobody, dork."
My online repair manual shows the fuel filter for an '04 Sierra on the frame rail.
Gary
your fuel filter is built into the fuel pump module NOT on the frame rail. And also. My 04 z71 wont spin a wheel ever since it was brand new. Your iac, is basicly built into your TB. I would check what your fuel pressure is and go from there. The spec is different for whatever engine you have a 5.3 T engine and a 5.3 Z engine are different pressures.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
