Airbags
I was thinking of putting airbags on my 85 GMC truck, and I need some help and pics. I need to know where to get started. I know I need to C-Notch my frame,remove my front fender wells, and cut my bed. Is there any thing else I would need to cut or remove? Also, what airbag setup will be best to start off with? I would appreciate any help. Thanks.
Re: Airbags
the front is easy...bags and upper/lower mounts. the rear requires a little more thought...step notch, bags, mounts, and a 4-link of some kind....and most of the cutting is done on the frame and bed floor.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Happy to be here
![]() Join Date: Mar 2000
Re: Airbags
There is a LOT to cover on how to properly set up an air suspension system. I suggest you spend some time in our Suspension Forum. Some research there will allow you to ask educated questions regarding what system will best fit your needs.
