Old 08-02-2011, 09:49 PM   #1
gno72
6 lug rotors/hub
Hey there! I'm doing some work on my 72. I had to change the rear end after the original exploded and now have a six lug rear. Could I either put my original axles in there, or. Is there a six lug rotor and hub I can swap in up front? I haven't been digging yet and I'm sure that one of you guys has been here already!
Thanks for the help guys!
New Toy
1972 Chevy C10
350/350 turbo w/B&M shift kit
Needs Parts!!!
gno72 is offline   Reply With Quote
Old 08-02-2011, 10:20 PM   #2
bw4sale
bw4sale's Avatar
Re: 6 lug rotors/hub
The original axles won't fit. They're too long I believe. You can buy conversion axles to make it 5 lug again but they're pricey IMO. I know you can buy 6 lug disc conversions, but I don't know if you can buy just the rotors.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 08-02-2011, 10:21 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You can buy direct fit 6-lug rotors from Early Classic Enterprises or Performance Online.com.
I would find a different rearend or put 5-lug axles in it.
Some of the 1970 trucks have the wider rearend.
If your new "6-lug" rearend was a 1970 version,... your old 5-lug axles with fit.
(some say the 1970 model year you could get both the wide or narrow housing with 6-lug axles)
My '70 stepside has the wide housing.
Keith
Convert to disc brakes.
Old 08-03-2011, 08:40 AM   #4
gno72
Thats some good information! Performanceonline has the rotors with and without hubs. it looks like the hub is part of the rotor on the 72, on the rear end would there be a casting number anywhere to id the part? i had a heck of a time finding one when i shotgunned mine! I blew about a 6 inch hole through the bottom of the original-you might say a catastrophic failure!
Thanks again for the advice-learning as i go
New Toy
1972 Chevy C10
Needs Parts!!!
Old 08-03-2011, 11:25 AM   #5
lolife99
lolife99's Avatar
Yes the hub is part of the rotor on all the 71-87 rotors.
What year truck did your current 6-lug rearend come out of?
Also take a "backing plate-to-backing plate" measurement, to determine the width.
The narrow 67-69 and (early 70) housings are 55.5" wide.
The wider (late 70) and 71-72 housings are 57" wide.
Keith
Old 08-03-2011, 03:53 PM   #6
kieth
kieth's Avatar
Have the 6 lug rear axle hubs welded up and the correct 5 lug pattern drilled out and new studs installed. It looks like this when you are finished cost me about $100.00 plus the studs....
http://kieth.smugmug.com/Trucks/66-G...86_ZfxoQ-X3-LB
be sure and check the diameter of your new5 hole brake durm, we had to turn the center down to the correct diameter so the new drum would fit. You might just want them to drill out the brake drum also.
kieth is offline   Reply With Quote
Old 08-03-2011, 08:25 PM   #7
gno72
I'll check with my machine shop on getting the hubs redrilled for 5's. How has that held up for? That would be the most econical way to go
New Toy
1972 Chevy C10
Needs Parts!!!
Old 08-06-2011, 04:06 PM   #8
michael bustamante
michael bustamante's Avatar
What youll notice with the 67-70 rear end is that the tires tuck in more in the rear now than they do the front. if youre ok with that, then I dont see a problem redrilling. if you got lucky though and got a later 70 rear end, do an axle swap. so measure before redrilling
1967custom
michael bustamante is offline   Reply With Quote
Old 08-06-2011, 07:32 PM   #9
SCOTI
SCOTI's Avatar
The narrower track width for the rear isn't as visible when using staggered wheels w/different back-spacing.
I would always consider new replacement axles first. They're stronger than what they were 39+yrs ago, they have zero bearing wear, & no fatigue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
