New 4 row Radiator, New Fan, New Water Pump and Stat - still running hot!
I just don't get it. This was a NAPA 4 row radiator. I jacked the front up when I filled and burped it. The pump and fan are new. Its driving me crazy. I couldn't put the shroud back on but still, that could not be it. I went around the block twice and hit 220. Somebody said it is possible for the water pump to look identical but rotate the other way. That is the only thing left I can think of.
What do you all think? |
The Older Generation
Re: New 4 row Radiator, New Fan, New Water Pump and Stat - still running hot!
Do you have any pictures of your pulley and belt setup you can post? You also may have a blockage somewhere in your water jacket. LockDoc
How are you measuring the temp?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Mar 2008
That's my first question too....we had a '56 Belair 2 weeks ago that was "overheating"....aftermarket electric gauge showed 220, original mechanical gauge read 190. We used a temp gun on the intake, block, heads, etc to rule out the temps being read. A water pump with straight fins on the impeller shouldn't care which direction water flows, you have to be careful when the impeller blades are curved one way or the other. |
having the same problem and i found some information that a fan shroud should help
WITNESS ![]() Dont be like me be better than me ![]() |
X3. A fan shroud is critical to force air through the radiator
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
You need a thermostat, otherwise the coolant travels through the radiator too fast to be cooled. I think that, plus no shroud are contributing factors to your problem, especially for in town driving. Just my 2¢ worth. LockDoc
Which gauge was right?
I am using a new mechanical gauge. I could not fit the shroud because the rad is thicker so I am going to shave it down and install it. I started to wonder if there is some type of necessary relationship between the flex-blade fan and shrouds. (I hate flex fans) Red Monster - what did you learn about the shrouds? I will try to get a pick. My worst fear is a water jacket blockage. I did lift the front when filling to ensure the heater core was below the radiator. Last edited by ubtripn; 08-04-2011 at 12:15 AM. |
Is the water/coolant physically overheating though? Not too sound like a jackass, but you need to start with the basics.
Is the thermostat opening, the upper rad hose getting hot? Is the coolant bubbling and hissing? Rad cap working okay? I disagree (as an opinion) with needing a shroud for the amount of driving you are talking about. I think you need to determine if the mill is overheating (with no help from the rad) vs. everything working together ('stat open, good coolant flow, etc.). Also, sometimes overlooked, if it's an A/C truck, if the condenser is plugged, the rad will receieve no airflow. Sometimes those little things when overlooked will bite you in the ass trying to chase a problem. |
~Rest In Peace~
take it to a smog machine and have them check for gases at the radiator, coming from the heads or block possible
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Yeah I have good flow, no thermostat right now, I have one waiting to go in but I figured a 4 row radiator with no stat should run very cool.
Thanks Fastwilly - I will do that. Coolant boiled at 215 and expelled out. I just burped it more, and could see the coolant running out of the flues with the cap off and the flow increased with RPM. Bubbles came out and now it is running 190 (88 degrees outside) until I stop to idle and it climbs to 210 then 220. I am hoping the shroud will fix that. |
i always take a known good thermometer and take the actual temp of the liquid to see if gauges are accurate
I'm impressed that no one has asked one key question:
Does it over heat with high speed driving or low speed driving. This is critical. If the fan shroud is missing the cooling fan is almost completely useless and it'll pull air from the space between the fan and the radiator. The shroud forces the air to be pulled through the radiator at low speeds (when the fan does most of its work.) Also, this is further proof that removing the thermostat, or running with a cooler thermostat doesn't prevent over heating. The thermostat sets the minimum coolant temperature, not the maximum. All a thermostat does is prevent the cooling system from functioning until a minimum operating temperature is met, then it "turns it on" so to speak. If the cooling system is broken, it doesn't matter when it's "turned on". My advice? Re-install the shroud, find a way, then see what happens. If the problem isn't solved, don't think the shroud wasn't the problem, look at it as a "contributing factor" that has been eliminated. Details matter! |
Quit if it's not FUN!!!
#15 |
Great point ll especially MagmaJCT - I did not re-install the shroud so I will be modifying it to fit today. (I replaced the 3 row with a four row)
You were right, slow speeds and idle were the problem and I could feel no air being pulled through the rad at idle. I think you nailed it. Going to do the work today and will repost tonight. Thanks all! |
#16 |
I had heating issues as well, new rad, all new hoses, new t-stat, flushed the system, had a shroud and all and still overheated, come to find out the clutch fan was not working so there was no air being pulled through when idling, I took the clutch fan off and drilled and put bolts through it to make it a direct drive, it hit 111 degrees here yesterday and it stayed right on the mark, did not run hot, that baby is pulling air now, will blow the tags on the radiator hoses now, best of luck
No one ever fell to the top of a mountain. When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend - ![]() |
#17 |
Rusty Nuts
The thermostat needs to be in for transfer of heat from the block back to the radiator. if water flow is two fast it will not transfer heat. Shroud needs to be on to route the air flow. Also improper timing will affect How hot or cool the engine runs but. and then if you have a clutch fan is it operating correctly. that all i can think of.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
#18 | ||
"I ain't nobody, dork."
Where do you have your temp sending unit installed? It should be in the drivers side cylinder head.
Gary
#19 |
Have you solved this yet? I suspect bigger problems then just a shroud. we run engines on test stands w/o shrouds and they don't overheat. Even at high rpm's. Cars and trucks years ago never had them. If your blade is too far back from the radiator i could see that it may have an effect.
#20 |
#21 |
Still working on shroud install And stat install. Will update when done. Sending unit mounts by the stat.
Posted via Mobile Device |
#22 |
I thought a thermostat either was open or closed not metering in between. Learn something new everyday.
#23 |
As someone else said, the thermostat temp is the minimum temp. After that it is supposed to regulate the temp so the motor runs at close to optimum (or design) temp. The valve in the thermostat is constantly moving as it tries to maintain a consistent temp after the motor warms past the design temp of the thermostat (160*, 180* etc). The radiator and water pump supply the coolant the thermostat asks for, all the parts work together, that's why it is called the "cooling system".
#24 | |
Sorry about the double post. |
#25 |
I soooo glad it worked out! You acutally had me sweatin'! Now take it easy and keep coooool. Good job!
