Old 08-03-2011, 11:15 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Another problem tailgate handle removal
How is the best way to get the 3 screws on back of tailgate for tailgate handle out, man they are tight. It has a chrome handle in it and I'm wanting to save it. Any help is appreciated, I soaked the 3 bolts with PB Blaster tonight with the gate down hoping it would penetrate some. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 08-03-2011, 11:41 PM   #2
72supermike
Re: Another problem tailgate handle removal
I had this problem once. The big screw driver wouldn't cut it. And tnot enough head to get a solid bite with vise grips. Sooo, do you have a welder? what I did is took a nut, and placed it over the head of the screw, and welded the nut to the head of the screw. You want a big enough nut that you can fill the inside up at the bottom where it touches the head of the screw. a small nut won't give you enough room to work with the welder and you end up just welding on the nut, and not really getting a solid bond to the screw. Then get out a wrench or sockets. Just the heating up and cooling of the screw will often times help break the bond. you might just heat it really hot and then cool it off and then try the screw driver before you get to welding. Good Luck!
72supermike is offline   Reply With Quote
Old 08-04-2011, 01:24 AM   #3
AirSpeed
AirSpeed's Avatar
I had to do the same thing supermike did, it works great. If you have no welder you can use a drill bit slightly smaller than the screws diameter and drill out the screws, you can the pop the head of with a cold chisel. You can also use a grinder to cut the head of the screws of, once you get them all cut off you should be able to use visegrips to grab the screw and turn them out.
AirSpeed is offline   Reply With Quote
Old 08-04-2011, 01:30 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
I used pb blaster then used the largest screwdriver and hit it with a rubber mallet a few times....then continued to tap it while turning....still didn't work....then I put vice grips on the screwdriver and pushed down on the screwdriver while I turned with the vice grips and they all came right out once I broke the initial rust seal on them...
Old 08-04-2011, 10:52 AM   #5
JORGIE95961
X2 i do this quite often
JORGIE95961 is offline   Reply With Quote
Old 08-04-2011, 01:45 AM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Have any of you ever used impact drivers? They are a device that you attach a socket with a hard bit of your choice. You strike the impact driver with a hammer and it multiplies the torque and helps shock the screw/bolt and walk it out similar to an impact wrench. I like the welding approach for these too. Good tip for sure 72SuperMike!
Here's an example of an impact driver/
http://buy1.snapon.com/catalog/item....1&group_ID=223
Ryan
1969 Chevy milk truck
Old 08-04-2011, 09:51 AM   #7
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Those impact drivers are pretty handy.
PB blaster isn't as effective as ATF/acetone mix, Kroil, or even liquid wrench. There was a link to a experiment on them somewhere where they measured ease of fastener removal.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 08-04-2011, 10:46 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
An impact driver does the same thing, but with more force and -- in my experience -- more effectiveness.
The few times I have needed to use it, my cheap Harbor Freight impact driver has worked very well. Looks something like this:
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-04-2011, 01:34 PM   #9
longhorn70gmc
longhorn70gmc's Avatar
When I have this issue, I get a sockit that will take the Philliups head and the breaker bar and as I turn it put all my weight into it and it seems to get more grab and torque when using the set up in this manner.
If you drill, I would utilize a small bit first and drill all the way through then utilize a larger bit to get the rest of it. This will also give you better control. I would not use a drill bit larger then the crew or hole.
Hope this helps my brother, GOOD LUCK.
R/
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 08-04-2011, 03:50 PM   #10
teeitup
teeitup's Avatar
Thanks for the help guys, I'm going to try the impact Fri, I found a buddy that has one. Thanks again, Randy
1980 chevy swb 4x4
Old 08-04-2011, 06:36 PM   #11
GDUB68
GDUB68's Avatar
I agree an impact driver and heat.
68 short stepside
68 camaro conv
30 model a coupe highboy
05 dodge magnum R/T
55 shoebox
GDUB68 is offline   Reply With Quote
