Old 08-05-2011, 08:09 PM   #1
vazquezguitarras
vazquezguitarras's Avatar
help with the exhaust manifold
Hi guys, I need help with my exaust manifold. It is of cast iron and it broke. It can not be weld, I want to know if you can make any modification to the intake manifold Because they are joined. My truck has a 250 inline six engine. Thank you very much for any help!
vazquezguitarras is offline   Reply With Quote
Old 08-05-2011, 09:18 PM   #2
Johnny Merder
Johnny Merder's Avatar
Re: help with the exhaust manifold
There are a lot of old wives tales when it comes to this, I welded my 6.6 drivers side with a mig welder and it is fine. it depend how much carbon has been absorbed into the metal as to how well it welds. it is worth a try.
Johnny Merder is offline   Reply With Quote
Old 08-05-2011, 09:32 PM   #3
vazquezguitarras
thanks!
Old 08-05-2011, 09:49 PM   #4
vazquezguitarras
Thank you very much I will consider.
Old 08-05-2011, 09:59 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
i've seen them weld v6s or v8s tho
your lucky it's out!
drill small holes at the ends to unstress it keep it from getting worse/longer first
then a cutoff to grind in a small clean groove
lookin but can't see your crack here
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-06-2011, 12:42 PM   #6
vazquezguitarras
Thank you very much for your help!
Old 08-06-2011, 12:36 AM   #7
rayfinseats
You CAN weld cast iron with arc welder. Must use stainless steel (nickel) welding rod. Can also braze with torch but must be red hot at all times during welding process. I would NOT recommend mig. I think you can use low-hydrogen rod too but not sure about that. Ask welding supply place.
rayfinseats is offline   Reply With Quote
Old 08-06-2011, 09:57 AM   #8
vazquezguitarras
Thank you very much, your advice is helpful!
