firewall pad with sound deadener?
I'm debating whether I should order a new firewall pad if I'm also going to cover that part of the firewall with the foil-back-type sound deadener - ?
I haven't checked the fit of my new carpet to see how far up under the dash it will go, but I definitely don't want the shiny silver backing staring at me. So how have you guys attacked this problem? Firewall pad OVER the deadener? Will the stock fasteners work with both (the sound deadener I have is maybe 3/16 - 1/4" thick)? |
Re: firewall pad with sound deadener?
i was wondering the samething! i'm leaning to doing the sound deadener under the pad just to have a lil more sound an heat out of the cab, but it's more up to you i would guess!! the fasteners will be able to go thru the deadener cause it stick out about a half inch or more on the firewall side!
i used both a stick on mat & the repro firewall pad on top of it.
Resistance is Futile
Not sure on this one but I installed carpet into my 'burb and I think it meets at the bottom of the firewall pad. I wanted it to be 12'' higher
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
OK, I kind of thought what you guys are saying, but didn't want to find out the hard way I was wrong.
My original pad was the thick insulation-backed cardboard with push-through plastic fasteners, although I've seen a non-insulated rubber version for sale on a couple of sites; will stick with the original if I can make it work. Thanks. |
I tried one of those cardboard pads-POS! I used sound deadener and foil backed pad, with carpeting. If I were to use a molded carpet and it was short, I'd get matching carpet for any exposed area. Most carpet sellers have matching carpet available-i.e. ACC and others.
I would use the foil based sound deadner (I used roof repair material from home depot)
we then added a/c duct insulation that has a sticky back and a foil cover, sealed all that up with silver tape. Then added the standard insulation pad. We used a full length and full height rubber mat so we could do the entire floor. do not have that installed yet. but it is quiet....Kieth |
![]() Join Date: Aug 2004
keith, can you tell me the name of what you used for sound deadner?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#10 | |
![]() ![]() <edit> You can see the roll in the second picture sitting on the trans tunnel.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
did it help? how thick is that stuff JimmyDean?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 08-11-2011 at 02:05 PM. |
World of difference. It has it's drawbacks, though. It melts in the heat, but so far hasn't been an issue around here, I just hope I never try to remove it. I have heard people say it stinks like roof tar when it's hot but only when new. I haven't noticed, but I also haven't been driving it.
There are better products out there that are designed to do the job. But in all honesty, unless you are building a car for sound comps it works great. If you have the coin or connections to Ram Mat or Fat Mat, I would use that instead. But when my truck is together, you won't know it's roof material under there. It is as quiet as a Cadillac. I haven't driven it since I put down my foam pad and carpet. But with just the Peel and Seal, it was a different truck. It's about 1/8" thick or less. If you have a stereo shop near by, get a wooden roller, helps the install. <edit> I spent under $100 for my whole floor. Deadener, 1/2" industrial carpet pad, 2 yards of top quality carpet. Still a few wrinkles in the carpet, but it's close. ![]() ![]()
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 08-11-2011 at 02:20 PM. |
I like your style Jimmydean! Think outside the box and come up with something cool. Nice work Bro!
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
