been here longer than Liz
Can't remove a/c compressor?!
Trying to replace the a/c compressor today. Problem is that the 3 bolts holding the comp to the bracket are blocked by the front of the pulley. Any ideas?
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Re: Can't remove a/c compressor?!
Bolts slide out forwards. Needing about 1/8" more room.
Pics?
What will you do to put it back on? |
![]() Join Date: Sep 2005
umm i need to see pictures to remenber what it looks liek and what i do i've done a few but can;t remenber frist hand
cut the bolt in half with a grinder and install a new one in the opposite direction.
Remove the front pulley.
Finally wiggled one out. Used that on the back end of the next one to hammer it through. Last one on the bottom, I had to hammer a flat spot on the pulley (couldn't get the pulley off) and got it out. Install of the new one went easy. Can't reverse the bolts, the heads are notched to fit an edge on the front of the bracket.
Those bolts usually have a flat side to the head so you can turn them and just barely wiggle them past the pulley.
Yup, that's what I was counting on. Something was just enough outta whack that they wouldn't clear the pulley by about 1/8".
I usually use a big pry bar to sneak 'em by.
