Air Conditioning
Anybody notice anything different?
Relax a second while I post some pictures.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: Air Conditioning
I started with a non-AC truck. I modified the firewall to be the same as a factory AC truck.
A little paint...
I used an A6 compressor out of a 1971 Monte Carlo I junked in 1994. I put some oil in it and every once in a while spun the compressor and made sure it worked.
I adjusted the POA to work with R134a. http://www.autoacforum.com/messagevi...AR_MSGDBTABLE= I flushed the compressor with modern oil that I purchased from ACkits.vom. BAV Auto 100. It is chartruse in color which helps with leak detection. After 3 or 4 flushes I figured it was good to go. The evaporator and condensor came out of a junk truck. I flushed them with mineral spirits. I purchased a new, aftermarket expansion valve from ACkits.com. A new aftermarket receiver/dryer from ACkits.com. And a new fan belt from NAPA. I pulled a vacuum. Let it sit for 30 minutes to make sure I had no leaks, then filled the system with 36 oz. of R134a.
You guys may not like wet spots on your shop floors but I sure don't mind a little condensation dripping off the evaporator in my shop.
Tasty Cakes!
Very nice! How's it working?
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
great work...you helped me out just by reading your post....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Nice job! How about inside the cab? Did you replace all the non air stuff? All the hoses, vents and controls, I mean. I have an air cab, but the heat and air components have been removed, I need some info on how it all goes back together.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Great job! I'm finishing mine up but I'm missing the spring that goes from the fresh air flap to the cowel, could you tell me how long this spring is and maybe post a picture of it. I can't button up my cowel without this spring and have no idea what to buy. (Lockdoc sent me one but it is the wrong style)
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#10 | |
I couldn't find that post but I did find the pictures. I don't have the length of the spring. What you need to know is that the spring holds the door open, vacuum works against the spring and closes it. I think with that information and the pictures below you can figure out what to use. Just measure from where it attaches to the flapper to where it attaches to the truck. I picked mine out of a parts drawer at my local hardware store.
#11 | |
Florida Edition
Junk Yartist
I don't have my truck close to go look at... does anyone know if the fresh air flap can be adapted to non-ac cabs?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#13 | |
A look at the LMC catalog helps if you don't have the factory assembly manual.
Thanks! I have some of the parts, but I did not remove them. I'll take a look at the catalog to see what I may be missing.
Gary
#15 |
Interested
IT IS WHAT IT IS |
#16 |
The kick panel parts are interchangeable. The cowl flap will fit, but you may have to drill a couple of holes to install it. If the cowl flap is not installed the "inside air" function (recirculate) on your control will not work. The cab will not get as cool on very hot days without this.
#17 |
Thanks for the info, glad to know they will fit. See if I can find them at a salvage yard.
#18 |
That might be a good idea, I don't know if they are available new. Also keep an eye on the parts for sale section here.
#19 |
Have you messed with any of the rubber seals inside the ducting. I have a question about the foot/center vent flap.
