08-09-2011, 09:55 PM | #1 |
new problem,speedocable HELP PLZZZZ
hi guys.
i installed the v8 and manual tranny from 1992 chevy truck.its look that the tranny work with electric cable.so my cable will not work.and i need to keep the original speedo meter.WHAT CAN I DO????
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress |
08-09-2011, 10:13 PM | #2 |
Re: new problem,speedocable HELP PLZZZZ
I know on motorcycles that you can buy an cable-to-electronic convertor. I think you should be able to find the same for what you need. I have done a ton of these conversions on old bike restorations in the past. I hope this helps. Good Luck!
08-09-2011, 10:23 PM | #3 |
I use the Abbott Cable X. It uses the electrical signal from the transmission and converts it to a motor speed that runs the mechanical speedometer.
Works well. You can also calibrate it to give the correct speed on the speedometer. http://www.abbott-tach.com/Welcome.html TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
08-09-2011, 10:32 PM | #4 |
$325. Not a cheap fix.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
08-10-2011, 08:52 PM | #5 |
08-10-2011, 10:03 PM | #6 |
You didn't say you wanted cheap. I wouldn't have bothered you with a response.
As far as I can tell Dakota Digital has nothing like what you need. If I understand correctly you want to convert an electronic speed sensor on the transmission to run a cable operated mechanical speedometer. If that is correct then I know of only two solutions. 1. A motor drive like the Cable-X to convert the electronic signal to motor speed to drive the cable. 2. Convert the transmission tail-shaft to a mechanical speedometer gear drive. Either solution is +$300. Check out this thread. http://ls1tech.com/forums/conversion...onversion.html If you want cheap, throw in an electronic speedometer. TR
08-10-2011, 08:53 PM | #7 | |
thanks
08-10-2011, 10:00 AM | #8 |
are you using the NV3500?
The nV3500 from an 88 or 89 has the mechanical speedo
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 08-10-2011 at 11:01 AM. |
08-10-2011, 08:51 PM | #9 |
its a 3 speed with granny gear.
08-10-2011, 09:23 PM | #10 | |
