Old 08-09-2011, 10:25 PM   #1
smittster
home depot peel and stick removal
I used the peel and stick tar based stuff from home depot on the inside of my truck. I want to remove some of them and they stick really well. Does anyone have suggestions on how to remove these more easily?
smittster is offline   Reply With Quote
Old 08-10-2011, 01:27 AM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: home depot peel and stick removal
I'd GUESS a heat gun ($10-15 @ Harbor Freight), a few good scrapers and some very rough steel wool for the remnants of goo that stay behind. Why remove it?
Dan in Pasadena is offline   Reply With Quote
Old 08-10-2011, 01:53 AM   #3
B17CRX
B17CRX's Avatar
Dry ice works very well to remove sound deadening material. Put the ice on the spots you want to remove, let sit, it becomes very brittle and comes off in chunks.
-Joel
B17CRX is offline   Reply With Quote
Old 08-10-2011, 02:42 AM   #4
Dan in Pasadena
-Joel
Smart!
Old 08-10-2011, 03:15 AM   #5
smittster
I think I will try the dry ice and a good scraper. I have a few pieces I laid down and I want to remove them so I could put down some other stuff down. I will be painting soon also.
Old 08-10-2011, 12:34 PM   #6
OrrieG
OrrieG's Avatar
Dry ice also works for removing vinyl floor tiles.
Old 08-11-2011, 08:09 PM   #7
mknittle
mknittle's Avatar
that must be what happened to my kitchen floor. gremlins snuck in at nite .
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-10-2011, 01:58 PM   #8
wildearp
wildearp's Avatar
Gasoline removes it from drill bits quite nicely, however it is risky due to flash hazard.
I would try mineral spirits first, and the possibly 50/50 mix of acetone and mineral spirits. I bet it will work very well.
Proper ventilation, PPE, etc......
wildearp is offline   Reply With Quote
