08-10-2011, 08:09 PM | #1 |
PROJECT 7DEUCE
Amp info...
I just parted a truck that has an orion 225-hcca and a carverm-240-07525 in it can anyone give me any info on these amps google was not much help.. I have a pair of kicker comp 12 subs and was wondering if these could possibly run them?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-10-2011, 09:10 PM | #2 |
Re: Amp info...
The Orion 225-hcca looks like a 25Wx2ch. The Carver M240 is 120Wx2ch.
It took about under a minute to find info on both through Google. |
08-11-2011, 02:30 AM | #3 |
Re: Amp info...
you could easly make a quick turn around on the orion if you sold it on ebay and probobely the same with the carver and get somthing newer. unless you want the old school stuff nothing wrong with it if it works but the're colectable to some people and even broken you could get a decent price for them just my .02, what kicker comps are they just regular comps or cvrs? and what ohms?
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s |
08-11-2011, 11:27 AM | #4 |
Re: Amp info...
The HCCA is a classic cheater amp. 25w x2 at 4ohms and 12v. I think the measured output on those was somewhere around 400w x2 at .5ohms and 14.4v. I know people who have gotten more than 600w a channel out of those, awesome amp.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
08-20-2011, 11:44 AM | #5 |
Re: Amp info...
i was about to post the same thing, they were a well known cheater in comps
68 SWB Fleet 383 |
08-21-2011, 10:48 PM | #6 |
PROJECT 7DEUCE
Re: Amp info...
Since im a noob at stereo stuff how do I go about getting 400 watts x 2? Looks like Im gonna off the carver amp...
08-22-2011, 11:04 AM | #7 | |
Re: Amp info...
Know that MOST amps don't support loads bellow 2ohms. So called "High Current" amps are designed for 1ohm or less load. We built a truck running four 10" subs and 14 component speakers off a 100watt amp in the pro class IASCA. Won nationals in '89 with that truck, too. So an example with that amp. Take two dual 2ohm voice coil subs. Each sub wired in parallel with itself is a 1ohm load. Wire both subs in parallel and you have a .5ohm load. If you used the 2 parallel subs and wired them to the bridged output of the amp, that would be a .25ohm load on the bridged channel. You would be looking at something close to 300W per sub, or 600w total dynamic output based on load. OK, that was a bit long but I hope that makes sense.
08-16-2011, 07:31 PM | #8 |
PROJECT 7DEUCE
Re: Amp info...
the 12s are kicker comp 12"s not the cvrs.and 4 or 8 ohms
