08-11-2011, 01:26 AM | #1 |
Ooops cut to much.
Lowered the front last weekend. Cut the coils to much... I am going to get me another used set soon. My question is can I go with air shocks in the front I have them in the back. I need new front shocks any way and I figured if I go with air shocks I can fill with extra air for the meantime.
77 k5 2wd 76 k5 jimmy 4x4 97 c1500 2wd 06 chrysler 300 on 22"s |
08-11-2011, 10:28 AM | #2 |
Re: Ooops cut to much.
I got geedy too and cut and cut until too late but looked good,don,t know about air shocks, could give them a whirl
08-11-2011, 10:45 AM | #3 |
I've never seen an airshock for a c-10 front suspension application. Buy new springs.
08-11-2011, 10:46 AM | #4 |
buy new springs, also you might consider replacing your sway bar mounts to the lower profile mounts for lowered applications.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-11-2011, 10:52 AM | #5 |
Or, you can remove the existing mounts & trim the sway-bar bushing bracket (piece that holds the bushing in place) so it fits on the top side of the existing bracket vs under it. Then reinstall the mounts w/bolts. This relocates the sway bar higher for sweat equity.
08-11-2011, 11:01 AM | #6 |
Happy to be here
No, you do not want air shocks. Even if you find a set that will fit, they will ride like crap. Do yourself a favor and use a good quality replacement shock once you get the spring issue corrected.
08-11-2011, 12:05 PM | #7 |
67-72 parts collector,…
How much spring did you cut?
1/2 coil usually equals about 1" of drop.
08-11-2011, 08:13 PM | #8 | |
No, to the air-shocks. The mounts can't take the weight of the truck, they will break something...
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-11-2011, 11:03 PM | #9 |
Thank you guys, picture (1) before I began. picture (2) 1st coil cut on driverside, way too much tire rubbed wheel well. picture (3) 2nd set coils too much. I hope the third set will be the last. I hope I don't screw things up when I go do the back.
