72 C-10 new crate motor installed, have questions on the late model serpintine belt
Hey guys looking for some help, I have a 72 sw c-10 i've recently installed a 330hp 350 HO Delux Crate motor from Chevy dealer. rigged it up at the time with old brakets and vee belts to get me running. i have recently purchased the SB Serpintine belt drive system deluxe W/air to install on the front of this motor to help with belt slipage. this system comes complete with all brackets, PS pump, 105 amp Altinater, Air compressor, reverse water pump, and pullies and belt needed. i'm ok with all that, but what i'm interested in knowing is: 1. is there any difference in the late model and early(stock) power steering pump? will the hoses connect and pumps serve the same purpose? 2: will the late model altinater connect to existing wiring? any help would be appreciated.. thanks guys..
Re: 72 C-10 new crate motor installed, have questions on the late model serpintine be
I did a s-10 blazer 4.3 to small block chevy conversion a few years ago and everything (serpentine belt system) unbolted from the 4.3 and re-installed it on my early model 350 without any problems. Good luck.
66 el Camino 70 1/2 RS Z-28 71 C10 2wd 72 2 wd Blazer (2) 72 4 x 4 Blazers 88 24' Mirage 70 mph+ 08 Harley Night Train 08 Silverado 4d 4 x 4 |
Car Craft did a nice article on this a few years back. You should be able to find I with a quick google search. I not I'll find it for you. It will answer all these questions and more.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
http://www.carcraft.com/techarticles...ive/index.html
#6 | |
Do a search on here there is a lot of info in different posts I also have a 4.3 serp setup on my truck just remember to get all the stuff off the front with waterpump etc
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
![]() Join Date: Nov 2007
I have the same crate engine, I used the serpentine system from the 96-98 Trucks. I know the p/s pump has metric fittings. A quick simple fix is to cut the end off to the p/s box side and re-flare it and use the s.a.e tube nut to work on the factory gearbox. The return line is no problem, its a cut to fit hose. My alternator was an 105 amp, I burned it because it needed a 5 watt 80 ohm resistor and I didnt use it. The reason it needs the resistor is because the 96-98 trucks use a charging lamp on the instrument cluster. If you dont use the charging lamp, you need the resistor. I hope this helps before you fry that alternator like I did
72 C20 Longbed 05 1500 Z71 |
#9 | |
Thanks fire dog, i'll dig in, appreciate your help..
#11 | |
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
![]() Join Date: Jan 2007
I just finished putting a 290hp gm crate motor with serpentine set up in a friends 74 crewcab. On the power steering, I just swapped the fitting on the p/s pump. The fitting just unscrews out of the pump and you can use your stock hoses. Everthing worked great.
You will need the resister between the white wire and the new alternator.
Hey thanks Mud, would have even thought about that, can't wait now to get home and look that over... appreciate your help and advise... you guys are awesome...
#15 |
Oh man its a very strong motor, plenty of power for the way i drive, runs good on pump gas, even with ethinal. great sounding idle, it is running a little rich and i think some carb tuning needs to be done, but i'd do it over in a heart beat... the timing was a 180 degs out when i went to fire it off and liked to have blow the breather off it, got it addusted and been cruzing ever since, i've been running the motor several years with the stock vee belts and they squill when i punch it, and i'm fixing to get the AC working so figured it was time to just swop over to the serpintine system and be done with it... i like staying org. on my truck but this just seems like the easiest way to go and maybe a bit more durable... my old motor was a stock 350 with auto trans, not sure what the HP was but it didn't run well at all when i purchused the truck and it leaked oil so bad couldn't keep it filled... so can't say much about old motor. got the money i'd say go for it, it works for me..
#16 |
#17 | |
#18 |
the link would not work for me..................??
#19 |
#20 |
remember your fan will turn the wrong way..
lee power stearing makes sae to metric adapters for the lines if you don't want to cut and reflare.. |
#21 |
Awesome stich! i'll look in to that... and yea knew i would need to reverse the fan but i'm hoping to go to electrict fan at some point, but will have to purchase a blade till then... thanks again...
#22 |
If u want to go to electric fan do the search on here for putting a Jeep electric fan in now. Fits right in the stock shroud and everything. All the reverse rotation fans that I found were about 40 bucks and they tell me that the Jeep fan is only a little more than that. Save a little money in the long run. Just my unsolicited 2 cents.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#23 | |
#24 | |
Everything fits fine. I even bought a shroud from LMC and will be getting a Clutch Fan for it next Month.
#25 |
Guys,
I'm just starting an engine swap in my 1972 Chev 4WD short box. I'm replacing the current 350 with the ZZ4 turn-key crate motor from Jegs. Will I have the same power steering (metric), alt (resister on the white wire), and fan (reversed) issues? |
