08-13-2011, 11:04 PM | #1 |
GMC frame and Chevy frame
Is the 1972 gmc frame The same as the 1972 chevy frame? Thanks.
08-15-2011, 03:19 AM | #2 |
Re: GMC frame and Chevy frame
I think the gmc has leafs in the back or most i have seen where.
08-15-2011, 09:06 AM | #3 |
Your right. gm has leafs.
wondering if frame dimensions and mounts are the same. |
08-15-2011, 06:26 PM | #4 |
They could be built either way depending on if it was ordered. Regardless of the suspension type, the bodies, sheet-metal, & mounts are interchangeable.
08-17-2011, 01:02 AM | #5 |
I changed from leaf to coilover on my 71 GMC and it was a 1/2" wider in the rear than other CHEVYs I measured. Dont know if it was just mine or if its all of them. Didnt have another GMC around to take a measurement on it.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
