08-17-2011, 03:22 AM | #1 |
feedback on 4th gen camaro gages in a 68
Almost none of my gauges were working accept for my speedo. I had wanted to do aftermarket but don't have the money right now. I came across a 97 z28 gauge cluster on ebay got it for 35$ shipped. My truck is fuel injected so i had the vss for the electric speedo. The rest of the gauges are all still analog so they work fine. Some of the wire colors were even the same as chevy used in 68. Pics aren't great had to use flash cause it was dark in garage. Tell me what you think. It turned out better than i thought. I may end up leaving it this way and using money for other needs the truck has. besides its different.
08-17-2011, 04:59 AM | #2 |
Re: feedback on 4th gen camaro gages in a 68
Me thinks you aced it for low bucks and good looking dash cluster to boot ...Ray
08-17-2011, 10:07 AM | #3 |
Grandpa in the rustmobile...
i like it alot better than the camaro tach in place of factory tach! it looks great! maybe some more blackpaint though..?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-17-2011, 11:10 AM | #4 |
Firefighter
Looks awesome!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
08-17-2011, 11:33 AM | #5 |
67cheby
COOL, different and unique
08-17-2011, 11:49 AM | #6 |
the only minor criticisms I can come up with is that it looks like it could come up an inch or two and be better spaced, and possibly have some sort of edge instead of it dropping from the flat of the plastic down into the gauge face itself (Maybe a little silver or something on the edge to make it transition smoother)
It really does look good just like it is!!! You even have some room in the corners for other gauges or switches if needed! |
08-17-2011, 12:41 PM | #7 |
You stole my thunder, i am literally doing the same thing! I originally looked into a 2000 blazer cluster but then found a 2000 z28 cluster in the junk yard and saw that it had the cutout for the steering wheel that we need so i got one off of ebay that wasn't broken. Still deciding whether i want to mount it in a glovebox door or add a plate to an original cluster to make it look nice. Good job!
08-17-2011, 02:11 PM | #8 |
thanks for the kind words. It is an old glove box door. as for the spacing its about as high as i could go. I wanted it a little higher but didn't have any more room. I also thought the same thing about something around the edge. Just couldn't decide what it should be. silver paint or maybe some kind of thin chrome trim. Might keep looking into that.
08-17-2011, 02:30 PM | #9 |
Not really diggin it, just doesn't flow.
08-17-2011, 03:07 PM | #10 |
LOVE IT !! looks great and as said its DIFFERENT...
08-17-2011, 05:52 PM | #11 |
you cant beat it for the cost since you're EFI. I don't think it looks bad, esp considering the money you've got in it. You would have hundreds in aftermarket gauges and a nice aluminum panel.
Doug Looking for a 67-72 short bed driver..... |
08-17-2011, 06:25 PM | #12 |
Personally, I like it
08-17-2011, 06:35 PM | #13 |
I admire you ingenuity and love the low buck aspect.
BTW, while i don't really hate it, I like the look of round gauges better, traditional round gauges go with the style of the truck better IMO. if i bought a truck with gauges like that, i would leave them for now, but put them on my list to upgrade when I had the cash. Just my .02 |
08-17-2011, 06:47 PM | #14 |
///Relaxed Atmosphere
creative, the reason i like this site, you see something different everyday
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
08-17-2011, 09:10 PM | #15 |
Old member
I like it. Have you got any shots of the wiring in the back? I'm fixing to install all speedhut gauges in a new dash if and when they arrive.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-18-2011, 01:52 AM | #16 |
Big Red - Now its a SWB!
Nice work! Though it's not my style, I have to give you points on ingenuity and the different factor.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
08-18-2011, 01:56 AM | #17 | |
'69 Chevy SWB
I've never been a fan of late model gauges in old vehicles. With that being said, I like it. No. I love it. It almost looks like it belongs there.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
08-18-2011, 02:57 AM | #18 |
i don't have any pics of the wiring sorry.
08-18-2011, 10:42 AM | #19 |
Nice fix. I was going to just try and use the speedo guts out of my 96 S10 Blazer console but I might look at the whole thing now since it has a Tach. Nice thinking.
08-18-2011, 11:03 AM | #20 |
that looks very good....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-18-2011, 04:50 PM | #21 |
Champagne Taste on Beer Budget
I'm diggin' it!
Personally I really like the long sweeping needles that that cluster has, it really stands out and looks slick!
Coming Soon: Project 1970 Country Truck |
08-18-2011, 04:59 PM | #22 |
I will give you my 2 cents I think it is very well done congrats
Fuzzy |
04-06-2017, 02:16 PM | #23 |
Sweet, I'm looking to do exactly this -- bought a cluster on ebay, a connector from delphi and pins to wire it up. Anyone have pics or ideas about how to fab this?
Also interested in connections to LS swap wiring. For instance will a stock LS oil pressure sender provide the correct output for these gauges?
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 04-06-2017 at 02:24 PM. |
04-07-2017, 12:32 PM | #24 |
Truly amazing! How did you fit that into the bezel??? I tried to buy a factory cluster with a corvette tach from craigslist 2 years ago, but the seller only spoke with me once, then would not answer calls, or return messages.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
04-07-2017, 12:57 PM | #25 |
Very nice work!
I have a cluster out of a 2002 Z28 if anyone may be interested. It was working fine when I parted the car out. PM me if interested.
1972 C10 Custom Deluxe 4.8 LS 4l60e |
