Old 08-17-2011, 07:49 PM   #1
67-72trucks
Who makes the best tool for installing solid rivets on crossmembers etc.?
Hello,
Started restoring a 71 GMC SWB 4x4. Having the frame powder coated. I am going to remove the rear leaf spring mounts cause they have swelled out some. I would like to keep it looking original as possible. Looking to buy the rivets and tool for installing them.
Thanks,
Mike
67-72trucks is offline   Reply With Quote
Old 08-17-2011, 10:03 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: Who makes the best tool for installing solid rivets on crossmembers etc.?
Check these guys out.
www.bigflatsrivet.com
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 08-17-2011, 10:04 PM   #3
Sammy
I would think the factory assy manual may give you a rivet diameter for the replacement. As far as rivet guns without spending serious coin do a search on ebay for rivet guns. Another is to find someone up around Seattle area go to a local pawn shop for decent deals on rivet tools and rivet heads for what you need. Pawn shops where Boeing or similar manufactures build aircraft. Most folks don't replace the rivets and just use grade 8 hardware but your set on returning to original. New rivets guns can run into a couple of thousand dollars used ones in working order hundred or two. A have a couple rivet guns quality names that I bought several years ago used and still work fine. Good luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-17-2011, 10:38 PM   #4
67-72trucks
Thanks!
Anyone interested in selling there used rivet guns? Have any rivets left over?
Old 08-18-2011, 06:15 PM   #5
67-72trucks
ttt
Old 08-18-2011, 09:15 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Set on rivits huh? Good luck I hate grinding them!
John
1999 Toyota Tacoma 4x4
Old 08-18-2011, 09:56 PM   #7
Indyuke
A pneumatic rivet squeezer. After getting it set up using some scrap metal, just stick the rivet in, pull the trigger and it makes a nice bucktail.
Indyuke is offline   Reply With Quote
Old 08-18-2011, 10:48 PM   #8
CrewCab59
CrewCab59's Avatar
Here is a thread ,we asked about the rivets.
http://67-72chevytrucks.com/vboard/s...d.php?t=464109
Scott
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 08-19-2011, 12:27 AM   #9
72swbcamo
Active Member
I replaced rivets on my front spring perches on my 72 4x4 short wheelbase. I got the rivets from bigflatsrivet.com. The folks their are very helpful. Their catalog has a whole section on how to install rivets. I bought a tool from them that fits an air chisel gun. you have to cut the rivet to the right length then heat it red hot. You place it in the hole use a backup tool and round the end with the air gun and the riveting tool. I got very good results
Here's some pictures.
72swbcamo is offline   Reply With Quote
Old 08-19-2011, 12:29 AM   #10
72swbcamo
Active Member
I replaced rivets on my front spring perches and on some cross members on my 72 4x4 short wheelbase. I got the rivets from bigflatsrivet.com. The folks their are very helpful. Their catalog has a whole section on how to install rivets. I bought a tool from them that fits an air chisel gun. You have to cut the rivet to the right length then heat it red hot. You place it in the hole use a backup tool and round the end with the air gun and the riveting tool. If the rivet cools off too much you just reheat it again and hit it again with the rivet tool.I the rivet rounding tool is not all that expensive. got very good results
Pictures are not too great but the results were satisfactory.
Old 08-19-2011, 12:44 PM   #11
67-72trucks
Nice Work!
Old 08-22-2011, 05:00 PM   #12
67-72trucks
what length rivets did you guys use? Thanks
Old 08-23-2011, 09:34 PM   #13
67-72trucks
ttt
