Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-18-2011, 11:13 PM   #1
litew8
litew8's Avatar
Any Zero Rust users out there? Need feedback
Any Zero Rust owners/users out there?
Need feedback good or bad on the product. If used, how long ago - is it holding up doing a good job or no? Any current pics of its longetivity? tia
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 08-18-2011, 11:22 PM   #2
BLUIDVL
BLUIDVL's Avatar
Re: Any Zero Rust users out there? Need feedback
I have used it on 3 frames so far and had no issues, the first frame was done over two years ago and still looks good. I have just recently made custom railings for my deck and sprayed it with zero rust, turned out great.
BLUIDVL is offline   Reply With Quote
Old 08-18-2011, 11:28 PM   #3
darkone
its really great stuff, not good in sunlight, and is soft and easy to eff up for a few weeks until it fully cures, but i tell you what, its some sticky sh*t!
darkone is offline   Reply With Quote
Old 08-18-2011, 11:38 PM   #4
treveiger
treveiger's Avatar
The people over at the autobodystore forum swear by that stuff an use it over por 15. When you shoot it spray it on THIN even coats to help with the drying/curing better. This is the only thing I'm gona use.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 08-19-2011, 01:07 AM   #5
litew8
litew8's Avatar
Yep, I've read similar. I've also read that (from ZR I think) the Red and Black are of equal quality. If wanting a black (satin I think) finish, to use the Red colored product for the first coat. Then when applying the second coat to use the Black. This allows the operator to see coverage better, allowing for accurate measurement of application. And yep, I read about applying thinly for procurement of the first coat - and then wait about 1/2 hour to 40 minutes before applying the second coat.
The problem I might have - my frame/parts were all sandblasted and primed for cab (and other) work. I think I'll have to try my best to remove the primer before applying ZR.
What do you guys think? If I put ZR right on top of the primer, do you think the primer will flake over the years? I know it isn't the best thing to do especially when ZR says to apply to bare metal - but some areas I won't be able to completely remove the primer. My first thoughts are - don't apply on top of primer - it needs to react to the metal itself.
Also, (again from ZR I think) I read that it'll last a good 5 years before you should re-inspect and touch up. Don't care about fading due to UV - I just want some good protection.
Old 08-19-2011, 01:35 AM   #6
treveiger
treveiger's Avatar
How thick is the primer? How hard would it be to remove most?
Old 08-19-2011, 03:14 AM   #7
litew8
litew8's Avatar
Not very I'd suspect in most areas. Surface rust formed after being hit by an unexpected rain shower, one night only (right after it was finished). I've read some things about etching primer, though I'm not sure it'd play a negative/positive effect in conjunction with ZR. I should find out the brand of primer used.
Old 08-19-2011, 02:48 PM   #8
litew8
litew8's Avatar
ttt
Old 08-19-2011, 05:24 PM   #9
TrkEnvy
Does it have to be sprayed or can you brush it on??
TrkEnvy is offline   Reply With Quote
Old 08-19-2011, 07:03 PM   #10
litew8
litew8's Avatar
You can spray (rattlecan) or brush it on. I'm going to spray if I do.
Old 08-23-2011, 11:08 PM   #11
litew8
litew8's Avatar
bump
Old 05-08-2012, 10:13 PM   #12
litew8
litew8's Avatar
Thanks to everyone who replied.
I did end up using ZR on a LOT of bare metal parts. Check my build thread for pics!
I'm very pleased with its coverage and adherence. I plan to spray the insides of my doors with it next.
Old 05-09-2012, 12:29 AM   #13
treveiger
treveiger's Avatar
Hey I hear nothing but great from zr
Old 05-09-2012, 12:54 PM   #14
litew8
litew8's Avatar
Very cool. Time will tell, wish I could find people that have used it over the decade to see their current status.
