Old 08-22-2011, 06:46 PM   #1
Tmwoodall
Wheel hits Tie Rod?
I just finished installing totally new everything except for the A arms and center link on my front end. I went to pop the wheels on so that I could set everything correctly. Well, the wheels hit the tie rod. I believe they are 15" Centerlines (I'll double check in just a bit). These are the wheels that were on the truck when I bought it. Maybe it rubbed then and I just had forgotten, as I quickly put 20's on it. I have since sold the 20s, and was doing to use the centerline for rollers until I was closer to completion to order the wheels I want.
Well as is, I can put the dang thing back on the ground. Did I mess something up, or are the wheels just too small? There is almost exactly an inch between the back face of the disc rotor and the edge of the knuckle/Tie rod end.
1972 Frame, and steering, with discs. Any tips/input?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 08-22-2011, 07:07 PM   #2
mrhino
Re: Wheel hits Tie Rod?
when you say everything, did you change spindles?
mrhino is offline   Reply With Quote
Old 08-22-2011, 07:08 PM   #3
Tmwoodall
Sorry, spindles are the same as before. Essentially moving parts. New Tie Rods, new pittman arm, new shafts in the a-arms, etc.
Not that it matters but i have the ECE 2/4 that has been on there since I bought it.
I should also note, I tried popping on some spacers I had laying around 1/2" I believe. Still would rub with those on there. Wheels are 15", just checked
