09-01-2011, 02:33 AM | #1 |
Hub Removal Issues
I'm removing the hub on an 82 K5 Blazer and can't seem to find complete directions. I've searched on here, google, and a few other sources. AllData doesn't give me everything I need to know. I've already removed the cover (It's manual locking hub) the Gear behind it, the Spring, then the two snap rings. There's a piece on the axle shaft I can't remove, and the inner locking mechanism I can't remove, for clarification I can post a pic in the morning. But I wanted to see if anyone had any clear directions on removing it.
Matt |
09-01-2011, 03:35 PM | #2 |
Re: Hub Removal Issues
Can I get ANY help at all? I've looked at tons of write-ups where they say that the locking hub unit should just pull out, but it's not doing so for me. Maybe the unit is rusted in there? It is pretty dry, but I can't be sure. Pics below.
09-01-2011, 04:57 PM | #3 |
I know the pieces fit
It is supposed to pull out. Is that the snap ring in the groove on the splines? Hard to tell with the funk there.
09-01-2011, 06:08 PM | #4 |
There's no snap ring on the splines. I see a washer behind the nut on the axle but thats it. It's like the hub is seized in there. It wont move at all.
09-01-2011, 07:15 PM | #5 |
Make sure theres no retainer ring around the outside of the cog in a groove in the housing. Id soak it in pb blast too
1967custom |
09-01-2011, 10:15 PM | #6 |
This is the one we've been mentioning, did you remove it?
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-01-2011, 10:24 PM | #7 |
I think it might be rusted in there
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
09-02-2011, 11:47 AM | #8 |
Farm Truck
This a good go by.
http://www.398hbx.com/home/gm-10-bol...ic-locking-hub
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
09-02-2011, 01:41 PM | #9 |
I removed the snap ring on the outer edge that you all are asking about, but still not coming out. As far as I can tell it's rusted in there. I've sprayed with WD-40, Vinegar, and Now I'm going to try PB Blaster and see if that helps. But I'm not expecting it to. So.... what next??
09-02-2011, 02:01 PM | #10 |
Looks like your next option is to heat up the outer hub a bit....carefully...also take a small wire brush and clean up all the rust....just to make sure the snap ring is not there....spray it again...next option is to get a slide hammer...fab up a plate steel to fasten to the allen head cap screws or a puller...with a hole in the bolt center ....it will come ..... take your time!!
09-04-2011, 02:39 AM | #11 | |
09-04-2011, 02:43 AM | #12 |
My Chevy had two of those outer "snap" rings.... possible there is a second on yours as well. Judging from your picture, looks like there may be another still in there... the gap at about the 11 o'clock position?
