Old 09-01-2011, 05:28 PM   #1
54foster
Rear end choices???
I recently picked up a project that someone else started, and I need some help. I have a 1954 body and a late model S-10 frame. The rear end is not going to work, so I was wondering what rear ends people use on these frame swaps. Thanks for your help, I'm sure I will be asking for a lot of help as I'm not the one who took either truck apart.
54foster is offline   Reply With Quote
Old 09-01-2011, 07:42 PM   #2
geoffcalii
Re: Rear end choices???
iv seen that most people on hear r using a 4x4 blazer rear end. i c ur right down the road from me a ways, im in hamilton oh. i drive the all stock 49 3100 as a daily. looking forward to cn more progress on this build as im still stock pileing parts to update mine
geoffcalii is offline   Reply With Quote
Old 09-01-2011, 08:02 PM   #3
chinquipin
We used 4x4 blazer on my dads, we used 8in wheels with 3in backspace, otherwise it wouldve still needed a small spacer on each side. I'm using a 12 bolt from 70 monte carlo on mine and so far seems to be perfect
chinquipin is offline   Reply With Quote
Old 09-01-2011, 08:06 PM   #4
54foster
geoffcalii thanks for the info and yes we are very close indeed. I may need your help from time to time just to see where some of the box of parts I have goes. I got a great deal on the truck just wish I had been the one to take the two apart. I will be starting a build thread on it very soon, just waiting to grab a few more missing parts.
Old 09-01-2011, 08:25 PM   #5
54foster
chinquipin thanks for the info I don't mind running a bit of a spacer if I have to, and I wondered about a 4x4 good to know someone used it and it worked. Stay tuned as I'm sure I will be asking a lot of questions.
Old 09-01-2011, 08:30 PM   #6
chinquipin
the nice thing about 4x4 blazer is that its a direct bolt in. I had to weld perches on the monte carlo rearend. I only used it because i wanted a high gear ratio because i won't be running a overdrive.
Old 09-01-2011, 08:52 PM   #7
Rigmover
In my 58 GMC i put a 8.5" 10 Bolt out of a 81 Chevy Burb 4x4 not to hard of a swap with few modifications.
Rigmover is offline   Reply With Quote
Old 09-01-2011, 10:25 PM   #8
geoffcalii
thats no problem 54foster, id b happy to help how ever i can. and i know ware theirs a 54 5window i tried getting parts off of but he'll only sell it whole.so it looks like i need to save for another one! lol
Old 09-01-2011, 10:43 PM   #9
BlueJeep
BlueJeep's Avatar
I used a 95 4wd rear axle in mine, and 1" spacers per side to run stock 2wd 15x7 wheels. The ZR2 s10 rear axle would be about perfect.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-02-2011, 10:59 AM   #10
54foster
Blue thanks for the info, I went through your build sheet and it looks good. I can use a lot of your info.
Old 09-02-2011, 03:49 PM   #11
geoffcalii
yup thats the one, he want way to much for it and yes its really ruff. i was hopeing to talk him down some tho. it would make a grate low buck cool old work truck of cruzer. but i wanted that front bumper w/the og bumperets
Old 09-02-2011, 10:57 AM   #12
54foster
My project is a 54 5 window, so if your only looking for parts off of it I may be willing to split the cost of it. Only if you tell me the truck is not in a junk yard behind the shopping center off of route 4. That guy is crazy and the truck is a complete rust bucket.
Old 09-02-2011, 09:18 PM   #13
booger1949
i used a 73 camaro rearend an i had to move the perches but its a highway gear that is in it so i get great gas mileage an i didnt have to use any wheel spacers,
booger1949 is offline   Reply With Quote
Old 09-13-2011, 01:17 PM   #14
99 to Life
99 to Life's Avatar
i'm using a 4x4 s-10 rear end with 2" spacers. with 58' biscane wheels though. But it has the look I am going for.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-13-2011, 05:41 PM   #15
StudioJAK
StudioJAK's Avatar
I'm using a olds bravada rear end came with disc, locker and 3:73 gears. perfect fit on stock frame. Should be a direct swap on a s-10 frame. Im running 15x10's in the rear, and they clear the inner bed rail with no spacers.
'51 Chevy 3100 longbed pickup - bagged/MII/4link/bravada 3:73 posi rear.
StudioJAK is offline   Reply With Quote
Old 09-15-2011, 03:03 PM   #16
54foster
Thanks for the pictures, does the bed fit and not hit the tires or brake calipers?
Old 09-15-2011, 03:43 PM   #17
StudioJAK
StudioJAK's Avatar
Here is a shot from the rear with it blocked with wood (Prior to 4-link) with bed on. The side shot is to show the 15x10 295/50R15 stick out about a 1 1/2" from the fender. Gonna have to widen them I have a shot looking down the inside with the bed on, ill post if i can find it.
