Old 09-02-2011, 12:20 AM   #1
355GoldieGM
355GoldieGM's Avatar
Lights!?
Im looking for square light modification examples or post because id like to have something brighter for my 81. Founds lots on round lights, not much on the square ones. Id like to be able to get that slight blue color wich i think are HID`s but a im open to other options also. Any help would be appreciated.
BAM BAM
My Project:
http://67-72chevytrucks.com/vboard/s...ghlight=goldie
355GoldieGM is offline   Reply With Quote
Old 09-02-2011, 01:39 AM   #2
bigwheel15
bigwheel15's Avatar
Re: Lights!?
I converted my headlights over to hid on my 81, used a set of sealed beam conversion headlamps similar to these: http://cgi.ebay.com/ebaymotors/Seale...item3366a65380. Note those have lenses like oem, not the 'crystal' or 'euro' style available. I then bought a 6000k hid kit from ddmtuning: http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit and installed those and I have to say it is probably one of the best investments on my truck. Id also recommend a relay harness for the hid kit(http://www.ddmtuning.com/Products/HI...Wiring-Harness)
bigwheel15 is offline   Reply With Quote
Old 09-06-2011, 12:31 PM   #3
355GoldieGM
Re: Lights!?
Sweet, i think this is pretty much what im looking for, and at around 150 bucks, i can understand why youd say its a good investment. The reason you changed the bulbs is simply because the ones in the kit where 3000k`s??
To get the slightly blue color i want i need the 6000k`s right? Do the low and highs still work like before (45/55). Couldnt of asked for a better answer, thanks a lot, specially for the links... its of much help. whould you have any pics of what they look like instaled? :P
BAM BAM
My Project:
Old 09-06-2011, 07:59 PM   #4
bigwheel15
bigwheel15's Avatar
Re: Lights!?
I changed the bulbs because when I purchased the new housings they came with h4 halogen bulbs. As for the blue color I have 6000k in mine and it is pretty much a perfect white with a slight (and I mean slight) light blue hue depending on the angle you look at them at. High beams and lows work just as they did from the factory so no worries there.
And I have a few pics somewhere, lemme track em down and ill post em up for you.
Oh and make sure to properly adjust them down to not bother oncoming traffic.
Old 09-13-2011, 07:58 PM   #5
355GoldieGM
Re: Lights!?
Thanks that would be much appreciated!
BAM BAM
My Project:
Old 09-02-2011, 12:10 PM   #6
hatzie
Moderator
hatzie's Avatar
Re: Lights!?
Modern Wrangler Headlights with a set of Bosch ISO relays to get max current to the bulbs. Most HID kits are very cheap and the light will blind oncoming traffic. The Wrangler Halogens meet US DOT in a Jeep and are noticeably brighter than sealed beams.
Old 09-05-2011, 12:06 AM   #7
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Lights!?
Great point. A lot of people don't consider how annoying improperly planned and incorrect headlamps are to the drivers around them.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 09-06-2011, 12:10 PM   #8
355GoldieGM
Re: Lights!?
I agree, nothing is more annoying then being blinded by oncomming traffic.
But all is a matter of ajustment.
BAM BAM
My Project:
Old 09-06-2011, 12:09 PM   #9
355GoldieGM
Re: Lights!?
Yeah i read that post but unfortunately for me, there round and i am indeed looking to swap out just the lights and not the whole front end. Thus keep my fugly square lights lol At the moment im driving around on the highs all the time and never get flashed or nothing. They really dont disperse alot of light.
So im willing to go towards hid so that maybe one day i may drive on the lows.
BAM BAM
My Project:
Old 09-02-2011, 12:31 PM   #10
kris's66lwb
resident wrencher
Re: Lights!?
Those are round and cool as hell but hes looking for square lights as am i
kris's66lwb is offline   Reply With Quote
Old 09-02-2011, 12:37 PM   #11
kris's66lwb
resident wrencher
Re: Lights!?
With the round eye kits do you need to run the relay set up like form lmc ?
Old 09-02-2011, 01:18 PM   #12
TheApocalyptican
TheApocalyptican's Avatar
Re: Lights!?
I run relays with a set of these and a set of these. I'm running 90/100 bulbs in the hi/lo set and 100 in the high beam only light.
Mine are still a yellow color. Which isn't quite what you're looking for, but unless you run true hids, then the only thing you are doing is buying colored bulbs, which will put out less light than if the bulbs were completely clear.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 09-04-2011, 09:31 AM   #13
hatzie
Moderator
hatzie's Avatar
Re: Lights!?
No you don't have to run relays. But. Relays will increase the light output from any Halogen or Sealed-Beam headlight because the old wire is not what it was years ago.
Those round eyes are DIY not a kit.
Old 09-02-2011, 10:16 PM   #14
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Lights!?
Ok I guess I'll chime in here with what I did to upgrade to H.I.D.'s in my '90 'Burb.... Here's a link to the write up I did of them last year. LARGE RECTANGULAR HEADLIGHT HID UPGRADE.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-03-2011, 09:11 AM   #15
RuralRoute C-30
RuralRoute C-30's Avatar
Re: Lights!?
One option you might consider for brighter lights is this conversion. About a year ago I went from the oem light on the left to the LMC style on the right:
Granted I did a bit more than just swap out headlights but the end result was more light even when the sun shines.
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 09-06-2011, 12:13 PM   #16
355GoldieGM
Re: Lights!?
Mark
What does the kit include and how much did it cost you...
there halogen i imagine?
BAM BAM
My Project:
Old 09-03-2011, 10:36 PM   #17
83chevyman
Re: Lights!?
got anymore pics of your truck mark?
83chevyman is offline   Reply With Quote
Old 09-06-2011, 12:56 PM   #18
muthstryker
muthstryker's Avatar
Re: Lights!?
Seriously, go with the LMC headlights and swap out the bulbs for some PIAAs.. The only way to run a true SAFE HID is to retrofit true projector headlights into your 4x6s.
muthstryker is offline   Reply With Quote
Old 09-06-2011, 10:17 PM   #19
rayfinseats
Re: Lights!?
On my 83 my halogen hi beams are brighter than all 4 of my driving lights. Not sure what they are but I can see about 30 miles ahead.
rayfinseats is offline   Reply With Quote
