Old 09-03-2011, 11:03 PM   #1
Tmwoodall
Need help ID'ing Pistons
I am trying to figure out if the PO was shooting me straight, or if I should just start totally over on this engine. These are supposedly TRW pistons. THe only markings I can find say U.S.A, and on the I believe 42 31P on the inner wall where it mounts to the arm. Nothing besides the .030 stamping on the top. I had this running years ago on the stand but decided to put a better breathing Edelbrock top end on it. So I'd really prefer to not pull them out, hence the cramped photographing area.
Any help? I was hoping to find a casting number so I could easily determine my compression ratio. Any and all help would be greatly appreciated.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 09-03-2011, 11:50 PM   #2
wilbilt
wilbilt's Avatar
Re: Need help ID'ing Pistons
That looks like a flat top "eyebrow" piston. It also looks like the valves have made contact with it (!) ?
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 09-04-2011, 12:06 AM   #3
Tmwoodall
I assume you mean because the edges of the dishing on the "eyebrows" look rough? I think that is just a combo of poor picture quality, and where I wiped them down looking for any casting numbers.
Old 09-04-2011, 12:18 AM   #4
Tmwoodall
Here we are, cleaned up a bit.
Old 09-04-2011, 12:24 AM   #5
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
I would guess a SilvOlite cast piston not a forged TRW that I have ever seen but thats just this reporters opinion..
Never argue with an idiot, they will bring you to their level and beat you with experience..
indianbullet is offline   Reply With Quote
Old 09-04-2011, 12:34 AM   #6
chevybuldr
chevybuldr's Avatar
Those are cast low compression pistons. the first pucture you showed the valves have made contact with the piston. They might be federal mogel not sure though. Pop one out and look at near the piston pin or inside on the skirt.
chevybuldr is offline   Reply With Quote
Old 09-04-2011, 12:55 AM   #7
Tmwoodall
Help me out here, I am new to being inside a block why are you guys saying it looks like contact was made? Here is that same piston cleaned up, I see no difference between it and any of the others.
I have never been anywhere near this close to the guts, so I didn't realize it was so easy to just pop out the piston. I spent close to an hour with my video scope straining my neck and eyes, and googling at random.
Chevybuldr you are the winner, FedMogul 423NP. Arh, another lie from the PO.
Old 09-04-2011, 11:14 AM   #8
chevybuldr
chevybuldr's Avatar
By the looks of your first picture looks like there are marks are on the valve reliefs. Now the question is what heads were on the motor? Small chamber or big chamber?
Old 09-04-2011, 11:17 AM   #9
Tmwoodall
I am 99% sure what you guys are seeIng is simply where I wiped off some of the carbon deposits and it settled on the reliefs looking like a hit. The piston shown in the fist post is the same one in my last post above.
882 heads originally.
