Old 09-04-2011, 10:34 PM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
Early 235 inline not oiling front half of rockers!
I have a 55-57 235 INLINE IN MY 54 TRUCK. I have noticed it is only oiling the rear rockers arms and not the front. No oil is coming out of the little holes up front in the rocker arms. The engine did sit for a while so Im sure that rocker tube is just clogged. Is there a way to clean it out without removing the entire tube/rocker assmebly?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-04-2011, 11:53 PM   #2
mr48chev
mr48chev's Avatar
Re: Early 235 inline not oiling front half of rockers!
I am pretty sure that the answer is no. I haven't done one for probably 40 years but it isn't a hard job to pull the assembly off and take it apart and clean everything out.
You will need to take the end plug out an clean out the bore of the shaft with something like a bore brush for a gun.
If the tips of the rockers are worn so that they are recessed where they hit the valves you should take them to a machine shop that can dress them. This isn't something that you want to try to do on a bench grinder or belt sander by hand.
Then you have to put everything back together in order with all the pieces in the correct places. And adjust the valves when you get it back together. No biggie but it needs to be done.
This might be a big help to you http://www.1954advance-design.com/We...brication.html
Old 09-05-2011, 02:07 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Your problem is not uncommon. 235 had oiling issues to the rockers.
Check the pressure at the block with a gauge. If its to low nothing you do will fix the rocker oiling problem. If the pressure is ok check it at the head and see if there is a restriction. if its ok the remove the shafts and clean them out. Check for fit of the rockers on the shaft and excessive grooving.. I wouldn't remove the end plugs you can get in there with a barrel brush and clean it enough use a drill bit and clean out the rocker feed holes. One fix is to pinch off the oiling tube after the bend as it comes off the rocker shaft there by forcing all the oil through the shaft. just don't pinch it off before the shaft.
The toiler tube in the picture is from a 60 235 and has the end pinched, Its at the top of the picture. Pinching it off only works if you have enough pressure.
Old 09-05-2011, 07:19 AM   #4
72freak
72freak's Avatar
[QUOTE=dwcsr;4882355].. I wouldn't remove the end plugs you can get in there with a barrel brush and clean it enough use a drill bit and clean out the rocker feed holes. QUOTE]
Is this supposed to say ...I would?
How would you get in theire with a brush without removing the end caps?
Thanks for the information....I have never palyed with one of these and didnt know where to begin.
Old 09-05-2011, 09:23 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
[quote=72freak;4882410]
The rocker shaft is 2 pieces and connects in the middle by the oiling tube from the head. The center end is open so DO NOT remove the end plugs you don't need to. The picture shows the pieces. If you leave the shafts on the truck and remove the end caps you will only get to the first bolt and no further. You must take the rocker sets off the truck remove the bolts to get a brush down the bore of the shaft. You could leave the rockers on the shafts as pictured. The rockers are left, right, intake and exhaust so there are 4 different rockers on the shaft and they need to go back on in order.
