09-05-2011, 07:52 PM | #1 |
Lower Ball Joint Falls Out
Okay guys, Im working on a 68 C10. I bought new ball joints for a 73 C10 and just picked up a full set of spindles, rotors from a 79 C10 at the scrap yard.
I installed the new ball joints in the 68's factory a arms and all seemed well. It took a press and some effort to press out the old ball joints but the drivers side lower joint went back in with ease. Problem is, once i installed the spindle, the lower ball joint fell out of the lower a arm. I tightened the ball joints nut on top but it still falls out of the a arm. Im gonna go out on a limb and assume this isnt normal?! Passenger side is in nice and tight as it should be. The way this thing falls out, one would figure it would have a snap ring on the top of the a arm installed to keep this from happening when driving. Anyone ever experienced this? |
09-05-2011, 08:00 PM | #2 |
67-72 parts collector,…
Re: Lower Ball Joint Falls Out
Replace the a-arm.
Something is wrong. They should press in and stay. Posted via Mobile Device
09-05-2011, 08:07 PM | #3 |
09-05-2011, 08:14 PM | #4 |
no need to replace control arms just get the oversized balljoints at your local autoparts store
09-05-2011, 08:24 PM | #5 |
this problem is common enough that there is a moog problem solver part for it. Like cdowns said, you should be able to get an oversized lbj from the parts store.
09-05-2011, 08:32 PM | #6 |
Old Skool Club
....which leads me to say that an old mechanic buddy said he's seen more than one of them welded-in.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
