Old 09-06-2011, 12:33 AM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Common Torque Procedure for the Front Wheels?
Tomorrow I'm going to grease the front wheel bearings (tips on the best stuff?) and torque down the spindles.
Is there a torque spec or trick procedure...Like,
"Torque to 40ftlbs and then back off on the crown nut to the next available hole for the pin"?
Anything like that? My manual is stock. So, I wondered if there is a current "right way" to do this other than what I could find in there.
And,...since I'm asking....Do I need to "bleed" the power steering unit? It's brand new. The truck's not running yet but is up on jacks getting
ready for the front clip to go on. No steering wheel on the column yet.
I just thought, ".....Before I put the clip on, I'll do X, Y and Z...".
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-06-2011, 09:19 AM   #2
cdowns
cdowns's Avatar
Re: Common Torque Procedure for the Front Wheels?
torqueing wheels is far overrated// look at racing they install them in a circular pattern in less than 14seconds and they're confident enough to drive them 200mph// me i've just tightened them up for the past 45+years and never had an issue
Old 09-06-2011, 09:34 AM   #3
John Pasinski
John Pasinski's Avatar
WOW! You're an old guy like me.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 09-06-2011, 09:41 AM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
thats because they dont care about the abuse they put on them ,they dont care if the rotors get out of shape they change them after every race ,
i would still torque the wheels in star pattern to the proper torque with TQ wrench
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-06-2011, 11:49 AM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
lol...as said above, they have been over-torqued and they same gun will be taking them off. How many of us carry an impact gun or send one with our wives when they go out? I worked for a tire store for 9 years and know the value of torquing lugs. The goal is to get the load even and tight enough to hold safely yet not so tight that they can't be removed with common tools that are in the back of most cars along with the spare. You torque "most" passenger lugs to about 80 lbs in a STAR or crisscross pattern.
prostreetC-10 is offline   Reply With Quote
Old 09-06-2011, 09:31 AM   #6
Alex Hayley
You need to preload the bearing by tightening the nut until the the bearing begins to drag, not bind, and then back off the nut to the next cotter pin hole. I do not use a torque. I believe these instructions match the service manual. I has been a while since I have pulled the hubs off.
The power steering pump and gear box will need to be bled. Once they are connected and filled, turn the steering wheel from right lock to left lock a few times to let the air out. Refill, and turn back and forth again. Repeat until the fluid level stays constant. This process is performed without the engine running...at least that is how I did it.
Alex Hayley is offline   Reply With Quote
Old 09-06-2011, 10:33 AM   #7
magwakeenercew2jh
Originally Posted by Alex Hayley View Post
You need to preload the bearing by tightening the nut until the the bearing begins to drag, not bind, and then back off the nut to the next cotter pin hole.....
Once they are connected and filled, turn the steering wheel from right lock to left lock a few times to let the air out. Refill, and turn back and forth again. Repeat until the fluid level stays constant. This process is performed without the engine running....
Perfect info. Thanks much.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-06-2011, 11:39 AM   #8
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
I have always spun them and torqued them down 20ft lbs, spin it, 30ft lbs, spin it then 40ftlbs. Then backed them all the way off and set them like Alex Hayley said. That seats the bearing first before you snug it up. I know it will be too late but I will see what the manual says when I get home this eve.
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
