09-06-2011, 03:26 PM | #1 |
Reusing Turbo 350 X-Member issues
I started to finish up my 5.3/4l60e swap by getting the transmission x-member in place and the tranny bolted to it. My truck previously had a 350/350 combo from the P.O. To save a few bucks, I wanted to see if I could reuse the old crossmember with new hardware.
When I went to look and see if the old Turbo 350 xmember would work, it seems to be a pretty darn near perfect bolt in for the xmember's stock location, but the Transmission Mount I'm using (single bolt style) Seems to be about 3/4 to 1 inch toward the driver's side from the original bolt hole in the mount. I checked the alignment of my motor and it seems to be in right, so is this something normal? I plan to take some measurements underneath the truck at the tailshaft to see if the transmission tailshaft is off by 3/4 to 1 inch or what the deal is. Has anyone else had this issue? |
09-06-2011, 04:29 PM | #2 |
Re: Reusing Turbo 350 X-Member issues
Mine did the same thing, so I went with this..
http://www.classicperform.com/Store/...uck/CP9427.htm
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-06-2011, 06:17 PM | #3 | |
09-07-2011, 11:15 AM | #4 |
I am using the stock TH350 mount moved back with my 4l80e.
used the stock holes in frame. Used stock 4l80e trans mount and elongated hole. stock motor mount with transdapt plates.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
09-07-2011, 11:18 AM | #5 |
Has more rust than truck...
I also used a $6.50 TH350 mount (2 bolt style) with the factory cross member. I did need to drill new holes in the frame because I moved the cross member back.
