09-07-2011, 12:37 AM | #1 |
Random lowering question...
I have been looking at all the different ways to lower the rear of my truck more and something raised a question, if you have a flip kit done on the rear and pull leaves out of the leaf pack wouldnt that be effectively raising the rear back up?
09-07-2011, 12:51 AM | #2 |
At the body shop.
Re: Random lowering question...
No because the axle sits on top of the main leaf. Removing springs will lower it further and increase axle wrap.
" That didnt make it any newer " " Dont antique the equipment " |
09-07-2011, 12:54 AM | #3 |
6.0 powered square
not necessary, its depends on how many leafs are in the spring pack, when I only had 3 leafs in the spring pack the rear was almost dropped 8" drop with a flip kit, then I added 2 leafs back in the pack it raised it to a 5" drop
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
09-07-2011, 02:01 AM | #4 |
yes.if the prings had 0 sag. however the trucks weight on the one spring and the overload spring, causes about 2.5 in. far more than the 1/2-3/4in of removed spring thickness.
