04-10-2003, 07:32 PM | #1 |
got the truck lowered
Just got it back..its a str 3" front and back drop...sure seamed to level it out. I was looking for a tad more rake...oh well
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
04-10-2003, 07:34 PM | #2 |
this is the B4
04-10-2003, 07:36 PM | #3 |
another
04-10-2003, 08:13 PM | #4 |
Progress = 0%
Ahhhhhh........ much better
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
04-10-2003, 08:17 PM | #5 |
Fabricate till you "puke"
thats set about what you want with the auto trans Jim. I like that cali rake also, but you will get better bite with a more level stance. Looks good......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-10-2003, 08:44 PM | #6 |
Senior Moment
I like It. Looks good Jim
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
04-10-2003, 08:54 PM | #7 |
Looks good Jim.
04-10-2003, 09:10 PM | #8 |
14.1 @ 96MPH
I like it...strangely, I think mine has more rake despite the fact that it has 2.5" front and 4" rear? How big are those rears?
Project1970 - LS1 Swap Complete! Last edited by Project1970; 04-10-2003 at 09:12 PM. |
04-10-2003, 09:15 PM | #9 |
your front tires look pretty tall. if you swap some 255/60/15's on the front they are about 27 inches tall or 245/60's a little shorter, but kinda small imo, it will gaive it more rake.
roll pan looks good too. if you keep making it look better and better your gonna ruin your sleeper effect
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-10-2003, 09:15 PM | #10 |
28x11.5x15 et streets.......im confused..lol
04-10-2003, 09:24 PM | #11 | |
04-10-2003, 09:27 PM | #12 |
fronts are 205/75/15
04-10-2003, 09:34 PM | #13 |
So, how did you do that?
I'd like mine level (it's butt sticks up quite a bit), but not sure how to go about it. |
04-10-2003, 09:42 PM | #14 |
I had a local shop do the drop..3" in front and 3"in the back..they used 3 inch drop srpings and different shocks
04-10-2003, 10:15 PM | #15 |
I like it - those 75/15's run a little tall. A 60 tire like previously metioned would give you a little more nose dive.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
04-10-2003, 10:39 PM | #16 |
14.1 @ 96MPH
Good point...the rest of the rake on mine, I bet, is the 245/60 front tires.
Project1970 - LS1 Swap Complete! |
04-10-2003, 10:50 PM | #17 |
bigjimzlll, looks better lowered. What pinion angle do you run on your rearend?
04-10-2003, 10:52 PM | #18 |
67-72 Addict!
Jim, that looks like what I need. It looks great lowered!........Jim
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-10-2003, 10:55 PM | #19 |
Thanks for all of the kind words..stroker I have no idea what the pinion angle is now. I have a 2 piece shaft, and it was the stock angle..I think (0) or maybe -2-3 degrees..it dosent twist too much
04-10-2003, 11:51 PM | #20 |
Registered Cruiser
The truck looks great Jim. Did you get an adjustable panhard bar? If not that much of a drop can throw your rear track way off. This could make it difficult to keep that hot rod pointed straight down the 1/4 mile.
I intend to live forever. So far, so good. |
04-10-2003, 11:55 PM | #21 |
they spent 2 hours in the alignment bay..its dead on perfect...we will see tomorrow night how it tracks down the 1320
