Old 09-07-2011, 10:39 AM   #1
lyrikz
PITbut
lyrikz's Avatar
1981 Chevy 454. What oil do i use???
The engine is new. Its finally going to start driving. I did the joe gibbs break in oil and procedure.. What oil do i run??
delo 400? 10w 40?
Its a standard flat tappet so i should be using something different then just standard oil right?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 09-07-2011, 12:29 PM   #2
Dark Knight
Dark Knight's Avatar
Re: 1981 Chevy 454. What oil do i use???
I use "Castroil Edge with Syntec Technology" 20W-50. It says right there on the back of the bottle "for use in classic cars equipped with flat-tappet camshafts". Or, I just saw that Rislone has come out with an additive that will allow you to run whatever oil you like. I might give that a try next time. Synthetics are expensive.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 09-07-2011, 01:31 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Talked to my engine builder and he said to use 3 oils.
Brad Penn
Joe Gibbs Racing
or
Valvoline VR1. It has the zinc in it.
Here is the thing. That Castrol that you use, it says that its for use in that flat tappet cams, but heres what some people arent getting. When they are updating their oiling standards they are "supposed" to back date to older vehicles. But the truth is that it doesnt. This is just coming from my engine builder. I run what he says to run.
Issue with the additive is how much exactly should you use?? Also there is an issue with the calcium in the non zinc oil that interacts with the zinc additive that also wears the cam..
Anywho. My thoughts were that if i ran synthetic i wouldnt have to worry about it... But i didnt get to ask him that. If synthetic is so good, wouldnt it stop premature cam wear???
and sold.
Old 09-07-2011, 02:53 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Just do what the engine builder recommends.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-08-2011, 10:51 AM   #5
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
X3
You should be able to ask your builder how your oil pressure is compared to what he built, and ask if it's a stock pump or HP.
Also A Good Napa Gold filter will help Oil pressure while a Fram will hurt it.
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 09-07-2011, 03:29 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i concor with led
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-07-2011, 09:07 PM   #7
Dark Knight
There's a thread on the engine and drivetrain forum by Ticker that explains the different types of oils safe for use in these engines. My machinist said that the castroil will work fine. He said that Joe Gibbs oil is good too. Bottom line is, as long as you followed the proper break-in procedures on your cam, it should live a long, healthy life. The ZDDP just helps it last a lot longer.
Old 09-07-2011, 11:01 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Ive started to use valvoline vr1, it was on sale for 2.99 at orielly, i should've bought all they had its around $4.99 qt now.
John
1999 Toyota Tacoma 4x4
Old 09-07-2011, 11:26 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Whats the oil pressure supposed to be at idle, then at 2500?
and sold.
Old 09-07-2011, 11:34 PM   #10
oldblue1968chevy
I have an HD pump, about 50 or something at idle. I dont know.
Whats yours?
John
Old 09-07-2011, 11:38 PM   #11
lyrikz
PITbut
lyrikz's Avatar
Whats yours?
WOW. 50?? Im 65 ish at 2500, and about 25-30 at idle.. hmmm
and sold.
Old 09-08-2011, 11:18 AM   #12
oldblue1968chevy
Yours is fine. I think Napa filters are WIX
John
