Lower control arm installation
When you re-install your lower control arms, how do you know where to line the CA as far as the little u-bolts go. Is there only one way they can be installed? I'm concerned I won't know how far back or forward to put them.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Lower control arm installation
I set mine to the wheel base (133" on my longhorn) I used a c-clamp to hold the tape measure, then set to the centerline of the lower ball joint. Don't forget to subtract half of the diameter of the rear axle tube.
454 MAKES IT ROAR
It should have a small indent on the CA shaft (see pic) that in turn locates on a nipple on the underside of the crossmember, then just tighten up your u-bolts, and provided your shaft is centered on the CA thats all you need to do.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Thanks, guys!!
