Old 09-10-2011, 07:03 PM   #1
oneperfectrun
oneperfectrun's Avatar
Caliper placement on disc conversion?
Hi guys. New member here from north Ms. I didn't see a thread to introduce myself so I'm doing it here. Great forum by the way!
I did most of the disc conversion on my '70 chevy c10 today. New spindles and have the disc mounted. Ran out of time this afternoon when I was putting calipers in place. Are they marked as to which side they go on? I just assumed the bleeder valves would go to the top and stuck them on that way but not sure the brake lines a gonna be right in that position. Any ideas? Like I said I ran out of time and didn't get to look at them very close to see if they were marked.
Thanks,
Jeff
oneperfectrun is offline   Reply With Quote
Old 09-10-2011, 07:53 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: Caliper placement on disc conversion?
Welcome,
Bleeders have to be on top to get air out when you fill them with fluid no matter what the lines are doing. You may need longer lines also. The factory drums may not work.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-10-2011, 08:26 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
oneperfectrun... welcome to the board.
Check out my build thread which covers the complete install of a disc brake upgrade on my '69. Click on Blank Slate.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-10-2011, 09:10 PM   #4
oneperfectrun
Thanks guys. I was thinkin the bleeders needed to be at the top just for that reason. The kit I bought came with the lines and they are long enough. Just seemed like they weren't placed right. I will work with em more tomorrow atternoon. Will be sure and check out that thread 72.
Old 09-10-2011, 10:20 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Caliper placement on disc conversion?
Yea when we buy kits for these things and they say bolt in, that doesn't mean in the exact same place as factory! It just means it has a bolt to use, well maybe it does!
Old 09-10-2011, 10:53 PM   #6
70cst
70cst's Avatar
Hay oneperfectrun ....
Just want to say and from Ohio.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-12-2011, 09:35 AM   #7
oneperfectrun
Got it all finished up late yesterday evening. The lines worked fine. Just need a good alignment now and a few miles to get the pads bedded in! Thanks guys!
