limited tool options
Hey folks!! I’ve been working on my 71 Chevy SWB since February... Started off as a SWB GMC and a long bed Cheyenne.. I am in the process of doing body work at the moment. I am very limited as I do not own a compressor or air tools.. I have some buddies with big ones at home. Since I don’t have a lot of time I usually go up and straighten out a little metal at a time... The problem is I need to prime these spots.. I’m getting really close to buying what they call automotive primer in a can and later on spraying some high build over it... So this a total no-no?
Re: limited tool options
tho not the best it is a heck of alot better and alot more protection than nuttin
Old Skool Club
![]() Join Date: Jun 2001
Protect it as well as you can from the moisture in the air.....primer may absorb it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Primer is relatively porous and does not provide protection. It is intended to promote bonding between the substrate material and the topcoat.
whoops.. i used to drive around inprimmered chevys all the time as a kid. and here i thought id at leat keep it from rusting./. so it doesnt work at all for that huh
