vortec heads on a 305?
i have a set should i bolt them on if so how much power will i have? also how much power does my 305 have now hp wise. i have a holley 600 edelbrock aluminum intake and headers?
![]() Join Date: Jul 2010
Re: vortec heads on a 305?
vortecs on a stock 305..not much..i say 165 or more..save em, cause you will have to have em milled down to get yoy cp ratio back to stock 305 specs.
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
350 vortecs or 305 vortecs?
350 vortec....
another question i found a 350 bored .030 beet sitting for a couple years its just the block so i got two questions if i build a 383 stroker how much will it be for all inclusive ive never built one or what will i need to just build up the block and have a 350 bored .030 over keep in mind i already have a carb intake and headers and vortec heads |
Make sure the valves will clear the cylinder, the bore on the 305 is smaller than the 350. It would be a shame to bolt those on and the valves wont open...
Posted via Mobile Device |
There are two ways to go about building a 383, find a 400 crank and have it machined, come up with the rotating assembly, or there are a couple companies that make a pre-machined crank and rotating assembly in a kit, Nothern Auto Parts sells a kit, 400 crank, rods, piston, bearings, the works, personally that would be the way I would go. Also, are they TRUE Vortec heads, or earlier center bolt heads off a G-block? G-blocks ran from 87 to 95 (I think) and then came the Vortec. The way to tell them apart is easy, the G-block heads will have six bolt holes for the intake on each side, the center two being almost straight up and down, compared to the front two and rear two, and the Vortec heads are missing the center two. If the later is the case you will need an aftermarket intake to run a carb, if they're the earlier set, you can carefully drill the center holes in the intake straighter, and make a spacer to go between the head of the bolt and the intake.
1998 Chevy Z71 1989 Chevy S-10 1978 Chevy K-10 1983 GMC K3500 1974 Chevy Cheyenne Super 20 4x4 |
I wouldnt waste them on a 305. On a 350 you can get 300 HP pretty easy. Nothern Auto Parts is in town here and a very reputable company.
