09-14-2011, 01:44 PM | #1 |
Help me choose the Correct VIN Plate/ID Plate
Is this the correct Vin Plate for my 1965 short bed fleet side?
If not please show me what Chevorlet installed in the door jam (Or something close as close to original as possible) Mine is missing. http://cgi.ebay.com/ebaymotors/UNIVE...item5d30054310 I need a vin plate but not sure what or where to buy one? |
09-14-2011, 01:54 PM | #2 |
Re: Help me choose the Correct VIN Plate/ID Plate
Did you read the whole discription? The orginal "data" plate didn't have a vin # !! You should just call the DMV and find out where your frame # should be and see if it matchs. If it does they may or may not put a new Vin tag on your body
09-14-2011, 01:54 PM | #3 |
"Where were you in '62?"
Where is my 60-66 Chevy or GMC vin number?
http://67-72chevytrucks.com/vboard/s...d.php?t=463671 Where is my 60-66 Chevy or GMC vin number? http://67-72chevytrucks.com/vboard/s...d.php?t=463671 Vin Number query http://67-72chevytrucks.com/vboard/s...d.php?t=402078 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's http://67-72chevytrucks.com/vboard/s...d.php?t=327764 Historical/This I know/60-66 Model Changes http://67-72chevytrucks.com/vboard/s...351107&page=10
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
09-14-2011, 02:47 PM | #4 |
like said before, your vin plate on your 65 is centered in the door jam on the drivers side, like pictured. the plate your refering to is the GVRW plate on the DS kick panel.
VIN will also be on frame, drivers side right behind the motor mount. well, some of the VIN will be there, last 8 I think.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-14-2011, 03:05 PM | #5 |
Depending on your state laws, you may not want to try anything tricky with a lost VIN. It would probably pay to be up front with the DMV and do as they direct you, or risk a heap of trouble. If you haven't already, go in and ask about it first, and take it from there. my .02
09-17-2011, 10:58 AM | #6 |
Easy Does It
Do you need to get a tag or title or something? otherwise you cannot buy a vin tag unless the dmv issues one- this could be a hassel? you could pop one off from a local junkyard and use it if you are trying to get it titled
09-17-2011, 12:33 PM | #7 | |
I know in California you can't use VIN's from a junk yard becuase all junked vehicles are required to have junk slips turned in to the DMV, I don't know if this goes for all states or not, but it's just something to consider.
Andy |
09-17-2011, 12:38 PM | #8 | |
But Found Her 25yrs Later!
Oregon Scrap yards and wrecking yards require a title. The VIN off of a wrecking yard vehicle belongs to that vehicle. Posted via Mobile Device
09-17-2011, 11:45 AM | #9 | |
Summerj, Why not use the VIN on you frame? Posted via Mobile Device
09-18-2011, 05:41 PM | #10 |
60-66 Nut
X2
If the VIN tag on the cab is missing, talk to your local DMV. No matter which state you live in, it is against the law to switch VIN tags.
09-19-2011, 09:45 AM | #11 |
OK Thanks guys.
Got it all figured out. Found the Vin stamped in the frame near motor mount. Ordered a new repo GVW id tag that goes in the Drivers side near door jamb. I now understand that this tag is not infact the "Vin Plate" but a Gross Vehicle Weight plate or Some call it a " ID Tag" It has various Build Info on it that also includes and some had the "Vin # on them. The VIN # is Stamped into The Frame near drivers side motor mount and that's what the State recognizes/goes by. Thank You all that were able to help. |
09-20-2011, 12:21 AM | #12 |
the VIN is also riveted to the driver's side door sill at the top - does yours have that? Do they match? I would submit that the riveted tag takes precedence over the frame one - folks do frame swaps, etc. If you have no VIN tag on the cab, then your frame VIN could be used as proof to get a new VIN tag with DMV's help - if you know (or at least can guess) that the frame and cab have not parted ways at some point.
