67-72 Addicted
14B Oversized Axle Seal to Repair Grooved Housing?
Hey, I’ve got a 1997K2500 with a 14 Bolt FF. When I did the brakes last I figured that I would replace the axle seals. At some point someone must have installed an “axle seal repair kit” because there is a Ring pressed onto the axle housing and the ID of the axle seal is larger than stock. I have talked to 2 GM stealerships and 2 auto parts places and no one can order me one. I would like to get another kit like this because I am afraid that the original housing could be grooved. If you have any info about this or part numbers I would really appreciate it. Thanks.
'72 K20 |
member #16
![]() Join Date: Dec 1999
Re: 14B Oversized Axle Seal to Repair Grooved Housing?
I would think parts stores or bearing stores should carry them.
http://www.vsm.skf.com/en-US/HeavyDu...ediSleeve.aspx
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Tags |
14 bolt, axle seal, oversized axle seal, repair |
