Old 09-18-2011, 09:05 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
How do I remove the gauge panel?
Is there a trick to getting out of the dash. I removed the screws but can't get it past the top of the opening and steering column. Do I need to loosen and lower the steering column?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-18-2011, 09:12 PM   #2
teeitup
Just like to part out trucks!!
teeitup's Avatar
Re: How do I remove the gauge panel?
yes sometimes you will need to do that to get one out
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 09-18-2011, 09:17 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Did you disconnect the speedo cable, wiring, and oil line? If it has a factory tach, you may have to lower the column to get it out cleanly, otherwise not.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-18-2011, 09:49 PM   #4
cpisani70@aol.com
cpisani70@aol.com's Avatar
Once you are certain all the wires,lines and cables are disconnected it should come out
cpisani70@aol.com is offline   Reply With Quote
Old 09-18-2011, 10:42 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Wiper/headilght swithc?
Wipers have a little screw that you gotta remove (this side of the dash)
Lights have a 'button' on the top of the switch behind the dash you gotta push down and pull the switch out from this side of the dahs
John
1999 Toyota Tacoma 4x4
Old 09-18-2011, 11:22 PM   #6
teeitup
teeitup's Avatar
I've had some trucks over the years that I had too let steering column down to get the gauge setup out. They weren't tachs just regular gauge setups
1980 chevy swb 4x4
Old 09-18-2011, 11:49 PM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
Thanks for all the responses, but is not the harness, oil line, speed-o cable, light or wiper switch that is preventing me from getting it out. The bottom of the guage panel is snug against the column and the inside metal gauge housing of the gauge panel is catching on the top of the gauge panel opening on the dash. I hope this description gives a visual of the issue.
I remember having the same issue before I had all the gauges hooked up.
Old 09-18-2011, 11:55 PM   #8
too much stuff
Roadtrip!
Just a couple of bolts will drop the column enough to get it out. You shouldn't have to drop it all the way.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 09-19-2011, 06:23 AM   #9
MikeyMan
I've had the same issue.
Spent alot of time prying, wedging, squeezing, and cursing trying to remove and install gauge panels. Even used a bottle jack once! I never thought about lowering the steering column back then.
My most recent project, removed a couple bolts and let the column drop a little bit.
Gauges then pulled right out. Piece of cake.
Wish I had Internet and this site 20 years ago!
MikeyMan is offline   Reply With Quote
Old 09-21-2011, 07:00 PM   #10
scorchingeng
I drop the steering column and let it sag every time. Remove the metal cover, then 2 bolts for the support hoop. Easy and prevents scratching your gauge bezel. I know, because I have pulled my cluster so many times because I am too cheap to buy all new gauges at once, so over the years I have replaced them all.
scorchingeng is offline   Reply With Quote
Old 09-25-2011, 10:03 PM   #11
jugernot
Life, Be In It.....
jugernot's Avatar
Well, I had to remove the Ebrake handle, its attachement bracket, the U clamp holding the column and then let the column hang free, to get the gauge panel out.
Thanks for all the input.
