09-19-2011, 12:22 PM | #1 |
Distributor Location ?
Buying a 1967 C-10 and one of the pictures is of the engine bay. The distributor is on the front and it's tilted towards the driver side. The alt is a high mount on the passenger side. I've never seen a Chevy V8 with a front mount from the factory. Is it a Chevy motor and if not what motors are front mount and tilted to the right when looking at it? Ford's aren't like that and I believe that Chryslers are tilted to the left. Thoughts?
09-19-2011, 12:48 PM | #2 |
Re: Distributor Location ?
Picture?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-19-2011, 01:02 PM | #3 |
sound like I know what it is, but I would need to see a picture first
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
09-19-2011, 01:04 PM | #4 |
Sorry only one that's in the for sale post. |
09-19-2011, 01:09 PM | #5 |
That one is a Buick engine
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-19-2011, 01:38 PM | #6 |
Thanks for the help guys. Now just to figure out what Buick engine it is. I would guess a 350.....need to figure out how it's hooked up to a factory 4 in the floor too. I didn't think that Chevy bellhousing matched the BOP.
09-19-2011, 05:49 PM | #7 |
As johnny cash said, with a little bit o' help from an A-dapter kit, unless they also swapped in a BOP trans.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-20-2011, 08:00 AM | #8 |
Pretty sure that is a 350. The 455s were wider. Buick-Olds-Pontiac bellhousings are kind of hard to find, but they are out there. Not sure if the bellhousing is a bolt-on to an original HD 4-sp trans, but I think it could be.
09-19-2011, 05:33 PM | #9 |
Its always something!
It could be a olds 350
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
09-20-2011, 05:07 PM | #10 |
Nope Olds the dist is in the rear like Chevy and Pontiac. It is a Buick, I could tell if is a 350 or 430/455 with a better picture.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
09-20-2011, 05:14 PM | #11 | |||
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." Last edited by 406 Q-ship; 09-20-2011 at 05:27 PM. |
09-20-2011, 09:03 PM | #12 |
The SM420 and the Muncie/Saginaw car trans use a smaller pilot hole in the bellhousing. The SM465 which is the most common truck 4 speed uses a larger pilot hole in the bellhousing. It is possible to open the hole up in the BOP bellhousing, but probably a different trans. Saginaw 4 speed most likely? But anything goes.
09-19-2011, 05:41 PM | #13 |
~Rest In Peace~
bop 350
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-19-2011, 05:52 PM | #14 |
looks like a 350, buick...... Hmm
09-19-2011, 07:37 PM | #15 |
Pontiac and Olds have distributor in rear.
09-19-2011, 08:56 PM | #16 |
Looks like a Buick to me, also......I had a '71 Skylark Custom, with a 350, back in high school, and it was crazy fast.
09-20-2011, 03:36 AM | #17 |
09-20-2011, 08:01 AM | #18 |
Well, he said it's a 4-in-the-floor, so I'm going to assume it's a 4 speed manual, in which case all Muncie, Saginaw, and BorgWarner transmissions will work with the BOP bellhousing.
My suggestion is for the OP to scope around some Buick forums to see how to find out which engine he has. The thing about BOP engines is that none of them made either a small block or big block. If I recall, though, one of them had a slightly taller deck on their 455 and the intakes wouldn't interchange.
09-20-2011, 10:52 AM | #19 |
Just a car guy
Is this the truck in question?
http://67-72chevytrucks.com/vboard/s...d.php?t=483128 Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
09-20-2011, 01:22 PM | #20 | |
http://dallas.craigslist.org/mdf/cto/2600813766.html |
09-20-2011, 11:30 AM | #21 |
301 and 326 pontiac blocks are smaller, but 350-455 block are the same size. Not familiar with "BO" motors so I cant comment.
09-20-2011, 01:59 PM | #22 | |
Old Skool Club
Buick had the 215 Fireball aluminum V8, until the 300 came out in '64. That engine grew into the 340, then the 350. The "Nailhead" V8 began in '52, but was gone with the 66's. A new 400, followed by a 455, came out for '67. Olds had the same aluminum V8 as Buick....literally. It was replaced by a 330 in '64, which became the 350. The 394 Olds engine was replaced for '67 with a 400 and then the 455.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-20-2011, 02:44 PM | #23 |
Champagne Taste on Beer Budget
Dang ChevLoRay that's some good history/information about those engines!
And the engine in question is not an Olds 350/455 for sure as I have the 455 with the dizzy in the rear of intake.
Coming Soon: Project 1970 Country Truck |
09-20-2011, 05:48 AM | #24 |
It's not a Pontiac 350... This is the Pontiac small block... Distributor in back.
1969 CST/10 "GreenAndWhite" 1974 Nova (SOLD... End of an Era) 2000 Impala (RIP) 2008 Malibu Brand Loyal... I've never owned a Vehicle not made by Chevrolet. |
