Old 09-24-2011, 07:14 AM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
Spine #
Does anyone know what # spine would be on my 1984 K10. It has the stock 10 bolt 8.5 Corp rear end. I have a chance to pick up new new ring and pinion / install kit. I know I could pull the shift off and look, but I am meeting up with the guy today.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 09-24-2011, 07:15 AM   #2
parrisc19844x4_468
Re: Spine #
whops. wrong place ..plz move
Old 09-24-2011, 07:21 AM   #3
parrisc19844x4_468
Spine 28 or 30?
spine #
Old 09-24-2011, 01:19 PM   #4
Heavy87Chevy
Heavy87Chevy's Avatar
Re: Spine #
I just rebuilt my rear diff a couple weeks ago & was looking into this stuff. I believe if its a 'standard' (non-locking) diff in the rear, it will be 28 spline & if its posi it should be 30 spline, you can find out if its 'standard' by looking at the RPO codes. I would expect it to be a standard diff given that its a 1/2 ton.
GQ1 REAR AXLE - STANDARD (NON-POSI)
G80 REAR AXLE - LOCKING TYPE
Heavy87Chevy is offline   Reply With Quote
Old 09-24-2011, 02:15 PM   #5
BIG V
Re: Spine #
actually in 1989-1991 ish only in the suburban and the blazers came with 30 spline axles your truck will have 28 spline axles, it doesn't matter if it has a posi or not. go to the loacal pick in pull if you want to upgrade the axles look for the blazers or burbs
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 09-24-2011, 04:25 PM   #6
Heavy87Chevy
Re: Spine #
You sure? my 87 1/2 ton had 30 splines. & it was a stock non posi rear.
Old 09-25-2011, 11:31 PM   #7
BIG V
Re: Spine #
I work at a differental shop have been for 13 years 99.9% positive American Axle Manufacture did not make a 30 spline untill 1988. Some of the 88 square body blazers and suburbans have 28 spline axles some have 30 spline axles. Its safer to say its from 89 on our square body's. However the 88 and up pickups all have 30 spline axles.
Old 09-25-2011, 07:17 AM   #8
parrisc19844x4_468
Re: Spine #
Thanks guys, that is why this forum is great.
I bought the set yesterday complete with the installation kit for $140. Gears have never been installed.
Got home and couldn't wait so i opened up the rear end, pulled the axles and front yoke off, pulled the gears. It is a 28 spline. What was supressing , well somewhat, was that the gears are like in the low 2's believe it or not. I need to get a new carrier for the 373's.
Old 09-25-2011, 09:50 AM   #9
ont_guy_38
ont_guy_38's Avatar
Re: Spine #
from 2.73 up use the same carrier so unless you have the 2.56 i think they are then you are good to go
ont_guy_38 is offline   Reply With Quote
spine, spine 28 or 30
