Old 04-13-2003, 03:38 AM   #1
MSL
MSL's Avatar
Question Gas and oil
If your oil smells like gas what could be the cause for this and how to fix it.?
MSL is offline   Reply With Quote
Old 04-13-2003, 05:05 AM   #2
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Your carb. could be running rich. If the engine is original or has some miles on it, the rings are probably a little worn, letting gas get by.
Your PCV valve might need to be replaced, not pulling a good enough vaccum and letting the gas fumes sit or giving a bad ring seal.
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 04-13-2003, 05:38 AM   #3
MSL
MSL's Avatar
Pcv valve is new plenty of pull there. as for the engine im sure it has mileage on it as for it being the orignal i have to get the numbers of the block to find out.
Old 04-13-2003, 08:17 AM   #4
rage'nrat638
rage'nrat638's Avatar
your fuel pump could be leaking into the engine also
rage'nrat638 is offline   Reply With Quote
