Salty Sailor
okay so recently i have finally found out from 1000 miles away why my lower control arms will not center up on the k frame. and it left me thinking if Rock Auto really skrewed up the lower a arms or if the "holes" in the lower control arm shaft are spaced further apart on a 3/4 ton than they are on a half ton.
because thats why my lower a arms have to come off and i have to pressure wash, paint, put new bushings, and transfer the balljoints into my original lower control arms.... i would just switch the shafts but the way they are connected to the control arm is different than the original. if yall recall from my build thread i had to modify the shock mounts to get the shocks to fit also. Rock Auto will be recieving a nasty letter from me once this is all resolved.
86 c-10 Custom Deluxe Savannah, Georgia |
Salty Sailor
here is a picture so yall get the idea of what im talking about
Re: 3/4 ton -vs- 1/2 ton question
1/2 ton will have rubber bushings in the control arm shafts and a washer and nut on the ends.
3/4 and 1 tons have steel bushings that thread on the end of the shaft AND into the control arm itself. it IS the nut and has a grease fitting in the center of the end. This one is a 3/4 ton steel bushing. ![]() |
Salty Sailor
Thanks for the help but thats the one thing i already knew. i want to know if the 3/4 arm will go on a 1/2 ton k-frame normally.
Salty Sailor
does anybody know if the tabs on the 3/4 ton k frame and 1/2 k frame are the same?
Salty Sailor
hope this will further explain what im needing to find out. if the distance between the two holes are different also if the bore size is the same
Just a quick question...what do you mean by a k-frame?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Salty Sailor
sorry i must be talking some Mopar talk haha. you know the x member where the engine sits on and in 2wd where the LCA mounts to
