What does a dually bed look like with the fenders removed?
What does a dually bed look like with the fenders removed? Are there holes, brackets, or trim on the outside of the bed? Is the inside of the bed the same as a standard bed? If any one has any pictures of a dually bed with the fenders off that would be a big help. I'm thinking of temporarily running a dually bed on a single rear wheel truck. Are they difficult to remove?
Thanks for your help! |
Re: What does a dually bed look like with the fenders removed?
Here you go. They are a little tough to remove. A ton of 1/2 inch wrench nuts.
GoatLube Experss
![]() Join Date: Oct 2009
it was easy to get mine off,,, ratchet wrench and a son with skinny arm's !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
Yes a ratchet wrench is a must. Weld a long steel extension on it. Makin it a custom long wrech, to get the corners. It does help.
Next!
Long thin wrench, like a tappet wrench, makes it a whole lot easier. Also easier to do with it upside down like I did.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
It's a regular bed with fenders
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
However the wheeling opening is larger on the dually bed.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Next!
yes it is
Thanks alot for the help guys! That's great info.
...and there's a filler piece in there that keeps the wheels from slinging the double-wall bedsides full of crap. Gotta have that!!!
![]() Join Date: Apr 2009
#12 | |
Any pictures of them? Thanks!
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
wish i could find one but one day
Edited by staff |
I took one to a sheetmetal shop and had a reverse made for the opposite side, they're kinda hard to find singly. I think I paid $25...
#15 |
Great Idea....Thanks
#16 |
Found pitures in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=492084
Anyone know if there's an aftermarket supplier on these?
#17 | |
Next!
#18 |
Well all right! Thanks man. Your truck is a big help.
#19 |
Honestly I figured that I would have to Fab them somehow. I need set also.
Has anyone tried a chevy dealer? I got lucky with dana 60 dust sheilds so I thought I would check. Havent yet though
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
#20 |
I just noticed one of mine was missing Sunday! At least now I know why the bed makes so much noise.
#21 |
I got fenders, fillers, lights and harness for sale. Local pickup only tho.
http://www.67-72chevytrucks.com/vboa...d.php?t=471706
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
